Calc Volume of Disk - Rotate Region Bounded by y=1+secx, y=3 About y=1
  • Thread starter Thread starter mateomy
    Disk Volume
The discussion focuses on calculating the volume of a solid formed by rotating the region bounded by the curves y = 1 + sec(x) and y = 3 about the line y = 1. The initial setup involves determining the area A(x) as π(sec^2 x - 4) and integrating from -π/3 to π/3. The user initially arrives at the volume of π(4π/3 - √3) but is confused by the book's answer of 2π. A participant points out a sign error and suggests using the property of even functions to simplify the integration, leading to the correct result of 2π.
  • Understanding of calculus concepts, particularly volume of revolution
  • Familiarity with trigonometric functions, specifically secant function
  • Knowledge of definite integrals and properties of even functions
  • Experience with integration techniques in calculus
  • Review the method for calculating volumes of solids of revolution using the disk method
  • Study the properties of even and odd functions in calculus
  • Practice integrating trigonometric functions, focusing on sec(x)
  • Explore common pitfalls in definite integrals and how to avoid sign errors
Students and educators in calculus, particularly those focusing on integration techniques and volume calculations, as well as anyone seeking to clarify common errors in evaluating definite integrals.
mateomy
Find the volume of the solid obtained by rotating the region bounded by the given curves about the specified line.
y= 1 + secx, y=3, about y=1
Set up:
1-1+secx= secx
1-3= -2
A(x)= \pi(secx)^2\,-\,\pi(-2)^2
=\pi(sec^2 x - 4)
<br /> \pi\int_{\frac{-\pi}{3}}^{\frac{\pi}{3}}\,(4-\sec^2x)\,dx<br />
All in all I come out with \pi(4\pi/3 - \sqrt{3})
The answer at the end of the book is telling me 2pi rather than pi, I can't figure out why. Can anyone explain this to me? THanks.
Set up:
1-1+secx= secx
1-3= -2
=\pi(sec^2 x - 4)
I think you probably made a sign error somewhere. Since your integrand is an even function, you can integrate between 0 and pi/3 and double that result.
This gives the right value.
2\pi\int_0^{\frac{\pi}{3}} (4-sec^2(x))~dx
AHHHH! I am usually super careful with keeping an eye out for the even/odd functions! THat makes it perfectly obvious, thanks a lot.
  • · Replies 19 ·
  • · Replies 34 ·
