Calculate E inside a spherical shell
The discussion revolves around calculating the electric field, E, at points inside a spherical shell with a uniform surface charge density, σ. The original poster attempts to apply Gauss's Law and explore a more direct approach using the Law of Cosines.
  • Participants discuss the application of Gauss's Law, noting that the enclosed charge is zero, leading to an electric field of zero inside the shell. They explore the calculation of E using spherical coordinates and the Law of Cosines, questioning how to express the electric field at arbitrary points within the shell.
Participants are actively engaging with the problem, providing hints and guidance on using spherical coordinates and integrating to find the electric field. There is a focus on clarifying the setup and ensuring the correct application of mathematical principles, though no consensus has been reached on the final approach.
Participants mention constraints such as the need for a diagram and the urgency of the assignment deadline. There is also a reference to the challenges of visualizing the problem correctly without proper tools for drawing.
lalover
Calculate the electric field, E, for general points inside a shell which has a radius R. It also has a uniform surface charge density, σ.
First, do it with Gauss’s Law.
Then find E more directly. Hint: Use Law of Cosines and a substitution.
I believe for the first part, the answer is just 0 since Q enclosed is 0.
The second part is where I need more help.
you are right for the first part.
For the second part, what is your working thus far?
How do you express the electric field at a point within the shell due to a point charge on the shell?
I am trying to use spherical coords. Therefore, an arbitrary point inside of the shell sould be (r,theta,phi) where r<R. I am trying to get script r (for the denominator of the equation for E).
Would that be (r-R, 0, 0). This is my trouble spot.
here's a hint for you:
Place the point in the shell for which you are trying to calculate the electric field on the z-axis. You should be able to see how to use the cosine rule from there. You can also easily switch back to using spherical coordinates for doing the integration.
The my script r becomes...
(script r)^2= R^2 +z^2 -2Rzcos(theta')
Will this still help me for points not on the z axis. If so, I still am not sure where to go.
you see, you are calculating for any arbitrary point in the shell. The point remains stationary when you do the integration. So you are free align your z-axis however you want it. Arbitrariness is not lost since you are free to align your z-axis.
By the way, your equation is correct. Now all you have to do is the integration.
For the integration, I can pull sigma out because it's constant. That leaves me with...
r-hat R^2 sin(theta')d(theta')d(phi') / R^2 +z^2 -2Rzcos(theta')
My bounds for d(theta') are 0 to Pi and my bounds for d(phi') are 0 to 2Pi?
Do I need to convert r-hat?
yes. Notice that for every loop around the sphere when you do the integration for phi, the horizontal components cancel. Now all you have to do is to add up the vertical components i.e. the components that run along the z-axis.
So would it be rcos(theta) that is added onto my integral instead of r-hat?
no. Look closely at your diagram. you need the horizontal component of the electric field vector.
I thought the horizontal components canceled and I needed the vertical ones?
oh yeh right the vertical ones i meant. you can find cos alpha, where alpha is the angle between the vertical and the electric field vector by considering the lengths of the triangle.
would sin alpha be R/z ?
No, cos alpha should be
[tex]\frac{R\cos{\theta}-z}{(R^2+z^2-2Rz\cos{\theta})^{(\frac{1}{2})}}[/tex]
the denominator is to the power of half, and the numerator is R costheta instead of R, the latex needs a while before it refreshes.
I think I am visualizing alpha and it's corresponding segments wrong.
That's just the definition for law of cosines. I don't know how to proceed from here though.
do you have a diagram to show? have you drawn your diagram correctly?
unfortunately my scanner sin't working properly right now and the assignment is due in an hour
well here is a hand drawn diagram using paint.
[PLAIN]http://img691.imageshack.us/img691/3497/32804960.jpg
14K
