Calculate lift from pressure distribution
12 replies · 5K views · last reply
Jurgen M
Free-body diagram of an airfoil with pressure loads shown as arrows on upper and lower surfaces, labelled F1 to F4, dF, dx, c/2, c, and pressure differences Ξ”p_g, Ξ”p_d, Ξ”p.
v=50m/s
βˆ†Pg= -981Pa
βˆ†π‘π‘‘ =490Pa
c=1m
𝜌 = 1,225 kg m3
Handwritten derivation: F1 = integral from 0 to c/2 of Ξ”p1 Β· 1 Β· dx = Ξ”pg Β· x evaluated from 0 to c/2 = Ξ”pg Β· c/2 = -981 Β· 1/2 = -490,5 N
Handwritten derivation of F2 as the integral from c/2 to c of 2 Ξ”p_g (1 βˆ’ x/c) dx, evaluating to 2 Β· (βˆ’981) Β· 1/8 = βˆ’245.25 N.
𝐹3 = ∫ βˆ†π‘3 βˆ™ 1 βˆ™ 𝑑π‘₯ 𝑐 2 0 = βˆ†π‘π‘” ∫ 2βˆ†π‘π‘‘ 𝑐 π‘₯𝑑π‘₯ 𝑐 2 0 = 2βˆ†π‘π‘‘ 𝑐 βˆ™ ( π‘₯ 2 2 ) c⁄2 | 0 = 2βˆ†π‘π‘‘ 𝑐 βˆ™ 𝑐 2 4 βˆ™ 2 = βˆ†π‘π‘‘ βˆ™ 𝑐 4 = 490,5 βˆ™ 1 4 = 122,625 N
Handwritten calculation: 490,5 Β· 1 divided by 4 equals 122,625 N.
Equations for the force F4 on the airfoil, integrating pressure difference over the chord from c/2 to c, giving 122,625 N.
Lift per unit of span = (F1) + (F2) +F3 + F4= 490.5+245.25+122,25+122,625=981N :confused:
Pressure push at all surfaces on airfoil,just push with less force on upper surface then lower surface, so F1 and F2 must has opposite direction than F3 ,F4.. so why they sum all forces with absolute values like pressure at upper surface pulling...?? pressure can not pull,only push :confused::confused::confused::confused:
Dont understand final lift math and force orientation..
  • Equation for F3: integral from 0 to c/2 of delta p3 dx equals delta pg times integral of 2 delta pd over c times x dx, which evaluates to delta pd times c over 4.
  • Handwritten line showing the freestream speed conversion V = 180 km/h = 180/3,6 = 50 m/s.
  • Two lines of handwritten-style equations: p = 101325 Pa and rho = 1,225 kg/m3.
It's not a pressure, but a ##\Delta p##, which is the pressure minus some baseline pressure. That can be negative.
If I know pressure distribution around airfoil, then geometry/shape/inclination of airfoil isn't necessary/relevant for calculate lift/drag?
The shape is relevant since it created the pressure distribution, but it is no longer necessary because the pressure distribution gives us all we need to know about the shape.
CORRECTION EDIT: The pressure distribution, surface area, and surface orientation are all needed to calculate the forces.
Same pressure distribution can have different airfoil shapes or inclination,so we don't know what is airfoil shape/angle from only pressure distribution.
Can you post some courses or videos or articles with examples of this lift calculation where I can learn better this topic?
I stand corrected. The pressure distribution, surface area, and surface orientation are all needed to calculate the forces.
What is surface orientation?
It is the direction the surface is tilted toward at that (infinitesimal) position. It is usually specified by the direction of the vector normal to the surface at that point. That normal vector is handy in cases like this because it is the direction of the force due to the pressure, ignoring the surface drag.
Diagram of an airfoil with pressure loads drawn as shaded arrows on upper and lower surfaces, showing F1, F2, F3 and F4 resultant forces, and labels for dx, x, c/2, c, and delta p.
calculate F3 from average pressure..
Handwritten equation: average pressure difference Ξ”pΜ„3 = Ξ”pΜ„4 = Ξ”p_d / 2 = 490.5 / 2 = 245.25 Pa.
Handwritten calculation of force F3 as the average pressure difference times chord c/2 times 1, with the result 122,625 N, using 245,25 and 1/2.
or with integral
Handwritten integral derivation of F3 = integral from 0 to c/2 of Ξ”p3 Β· 1 Β· dx = Ξ”pg times integral from 0 to c/2 of (2Ξ”pd/c)x dx, evaluated as Ξ”pdΒ·c/4.
Why they calculate F3 like pressure distribution "triangle" act at bottom airfoil surface from 0 to C/2?
If I see there is no pressure distribution at bottom surface from 0 to X, pressure distribution is drawn from X to C/2
Since there are no surface angles provided, it looks to me like all of the pressures are vertical components only (simplified problem). So while there are certainly positive pressures on the airfoil from 0-X, the orientation of the airfoil surface makes the vertical component negligible.
The pressure plot is based at the zero line not the lower wing surface, I made mistake because I look at surface..
What surface angle you mean?
You don't need the surface angle. You can just assume it's all acting perpendicular but acting on the projected area rather than the true area. Sure, the actual pressure force acts along the surface normal, but the vertical component is the same proportion of the total force as the projected horizontal area is of the total area, so all the angle dependence cancels out. For the calculation, you can just treat all of those as if they're acting vertically on a flat horizontal plate and you'll get the correct answer.
Consider that for same airfoil, the patterns of pressure distribution will change as AOA changes.
Also, high pressure differentials can’t be sustained close to the wing tips because some mass of air will naturally flow span-wise from areas of higher pressure to areas of lower pressure.
Please, see:
https://www.mh-aerotools.de/airfoils/velocitydistributions.htm
https://www.rcuniverse.com/forum/attachment.php?attachmentid=1385606&d=1375503690
πŸ™‚
