Calculate Line Integrals for Vector Field F on C1 and C2
The problem involves calculating the line integral of a vector field F along two line segments, C1 and C2, connecting specified points in three-dimensional space. The vector field is defined as F = yz i + (xz - e^(z)sin(y)) j + (e^(z)cos(y) + xy) k.
  • Participants discuss the parametrization of the line segments and the setup of the integral for C1, with some expressing uncertainty about the correctness of their parameterization. Questions arise regarding the implications of the curl of F and its relationship to path independence.
The discussion is ongoing, with participants providing hints and suggestions for correctly parameterizing the line segments. There is a recognition of the potential to evaluate the integral using the gradient method, although some participants emphasize the need to follow the specific path for the integral as originally stated.
Participants are grappling with the correct parametrization of the line segments and the implications of the vector field's properties, such as whether it is conservative. There is also a mention of the original problem's wording, which may influence the approach taken.
hils0005
Calculate \intF dr if C = C1 + C2 where C1 is the line segment from P1(-1,pi,-1) to P2(0,0,0) and C2 is the line segment from P2(0,0,0) to P3(2,0,4)
vectorF= yz i + (xz - e^(z)siny) j + (e^(z)cosy + xy) k
Im having problems setting up the C1 integral:
I have it parametrized as x=t, y=-pi t z=t, as t goes 0 to 1
r(t)= t i - pit j + t k
r'(t)= i - pi j + k
F= -pi t^2 i + (t^2-e^(t)sin(pit)) j + (e^(t)cos(pit) + pit^2) k
F dot r'(t) = -pi t^2 + pi e^(t)sin(pit) + e^tcos(pit)
I would then take integral dt as t goes from 0 to 1
I think I have answered C2 correctly, I'm not sure if my parameters are correct
Big time-saving hint: What is curl F ?
dF2/dx - dF1/dy =0 z-z=0
dF3/dy - dF2/dz =0 (-e^zsiny + x) + (-x + e^zsiny) = 0
dF1/dz - dF3/dx = 0 y-y=0
Curl test?? how does that help?
So what does that tell you about F?
that it is path independent or conservative?
Yes, which also tells you that you can write F as the gradient of some scalar \varphi...So if you can find such a scalar, you can easily compute the path integral using the fundamental theorem of gradients.
However, the way your original question is worded leads e to believe that they want you to evaluate the path integral along that specific path, so I would use the gradient method only as a check.
hils0005 said:
C1 is the line segment from P1(-1,pi,-1) to P2(0,0,0)...
That doesn't seem right; r(0)=(0,0,0) which is not your starting point, and r(1)=(1,-\pi,1) which is neither your starting point or your finish point!:eek:
x=t-1
y= pi t + t
z=t-1
t goes from -2 to -1,
would that work?
hils0005 said:
x=t-1
y= pi t + t
z=t-1
would that work?
Nope; now your starting point is r(-2)=(-3,-2pi-2,-3) and your finish point is just as incorrect.
Let's think this through logically instead of stabbing blindly in the dark...You know that c1 is the direct line from P1 to P2; so you can write down a general parameterized line for r: \mathbf{r}(t)=(at+b,ct+d,ft+g)...say you let t go from 0 to 1; what must a,b,c,d,f and g be for \mathbf{r}(0) to be P1 and \mathbf{r}(1) to be P2?
x=t-1
y=pit^2
z=t-1
x and z look good, but y isn't even linear in t!...how did you come up with that? Is y(1) really 0?
its late...what else can i say
I don't know what to use for t going from 0 to 1
y=pi t + pi
y(0)=pi
y(1)=2pi
y=pit - pi
y(0)=-pi
y(1)=pi t - pi=0
well now y is linear, and y(1)=0 :smile: , but y(0)=-pi not +pi:frown:
Perhaps you should get some rest and leave this until morning? :wink:
Great idea, thanks for your help
r'(t)= i - pi j + k
Here's a big hint for finding x, y and z,
So, we have (-1, pi, -1) + some t
(-1, pi,-1)+(1,a, b)t
So x= -1+t
I got this by having our original point and taking 0 from our second point and and -1 from the first point.
So, we have -1+[0-(-1)]t=-1+t
Follow this in the same manner for finding y and z.
Actually my intention wasn't to find the scalar potential which itself could be rather tedious, but to show that one could evaluate the line integral from P1 to P3 directly bypassing P2 to save time.
