Calculate magnetic field intensity
62 replies · 16K views · last reply
I guess I used RHR wrong the second time would it be +Z again or is it on the Y-axis? Is there an easier way for me to see this?
Well I think I found and appropriate equation setup for the into the page part H=I/2(pi)rho=(5/(pi)(4))k
so that would be an acceptable answer then accept that I must add units A/m or should I get the magnitude and angle and put in phasor form
whoops forgot about part b heh well assuming that it is worked the same then ry=sqrt((-1,2,2)-(0,4,0))=3 and rz=sqrt((-1,2,2)-(0,0,4))=3 and H=H1+H2=(10/(2(pi)3))k+(10/(2(pi)3))j
I would leave it in terms of i and j.
For part (b) it's different.
The first question you should ask yourself: does it matter what the x compoent of the observation point is?
for the first part no because it is 0 howeverI sense that it is different for part b
well I drew this thing on paper if I did it right the one that is into the page is on the x axis
I believe the other is on the y but I am not sure?
it would lie on the negative side of the x-axis right?
I guess it doesn't matter as the two wires both have a 0 x component
The point is the only thing that has an x component of -1
The two wires run from x = -∞ to x = + ∞.
So that's not the reason.
Think again: as you move along the x-axis a fixed distance away from either wire, does the H field change?
DODGEVIPER13 said:
If the distance from either wire is fixed then no
OK, so how can we make life easier by altering the second observation point (-1,2,2) without changing H at any given (x,y,z)?
im really sorry man for dragging this out I am just trying to understand. That being said if you change positions of course you will change the strength, right?
As x changes, does H change?
DODGEVIPER13 said:
I think so when I said no you said I was wrong?
Why would H change as you move along it, keeping the same perpendicular distance from it? The wire is infinitely long!
DODGEVIPER13 said:
ok so i was correct before and it doesn't change
Yes. I didn't feel youunderstood why. Just gussing right does not help you understand.
Anyway, OK, so how do we write (-1,2,2) if we want to put the observation point in the yz plane? This step is not really necessary but helps to visualize things.
well your right I am not understanding. Do you have any tips on that? As to your question you should draw the x-axis line so that it is parallel to the two wires. One side of that line will lie in the yz plane which is where it should be marked
