Calculate Mass of Material for Hollow Spherical Shell
  • Thread starter Thread starter rumaithya
    Mass Material
To calculate the mass of a hollow spherical shell with inner radius r1 and outer radius r2, first find the volume by subtracting the volume of the inner sphere from the outer sphere, using the formula V = (4/3)π(r2^3 - r1^3). The mass can then be determined by multiplying this volume by the material's density, ρ. The discussion emphasizes that r1 and r2 serve as variables representing any numerical values, allowing for a general application of the formula. This approach provides a convenient way to calculate the mass for any specific hollow spherical shell. Understanding the relationship between volume and mass is crucial for accurate calculations.
rumaithya
Hello,
How can we find the mass of a material with density p is required to make a hollow spherical shell having inner radius r1 and outer radius r2 ?
Thanks
rumaithya said:
Hello,
Thanks
Find the volume of the shell by taking the volume of a sphere or radius r2 and subtract out the volume of a sphere of radius r1. Then multiply the mass density times the volume.
Pete
What is the volume of r1 and r2 ?! there isn't any given numbers
Yes, there are! r1 and r2 are numbers.
The volume of the hollow shell is \frac{4\pi}{3} (r_1^3-r_2^3). Now multiply by ρ to get the mass.
Hint: The volume of a sphere of radius r is V = \frac{4}{3}\pi r^3.
Pete
you can think of r1 and r2 as just representations of numbers. It is a way of representing ANY number rather than one particular number. By doing this, if you have any sphere of any radius, you can just plug in the number you want to calculate in place of r1 and r2. This gives you a convienet equation that is applicable to any situation.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
