Calculate Min Weight to Contain 1 m3 Helium/Hydrogen
  • Thread starter Thread starter Krishna prasad
    Weight
To determine the minimum weight required to contain 1 m³ of helium or hydrogen at normal atmospheric pressure, one must consider the balance of forces acting on the container. The gravitational force (F_g = mg) must equal the buoyant force (F_B = ρVg) for the container to remain stationary. By setting these two forces equal, the mass (m) can be calculated. This problem is commonly addressed in physics textbooks, emphasizing the importance of understanding buoyancy and gravitational forces. The solution involves basic principles of fluid mechanics and can be derived without advanced theories like general relativity.
Krishna prasad
Hi,
I am a bit new to this area of physics.
My question:
1) How much minimum weight (in milligrams or grams) is required to keep 1 m3 (1 meter cube) of Helium / Hydrogen contained in a container of negligible weight at normal atmospheric pressure (outside pressure).
This question has been bugging me since my childhood and I am not able to gather an answer for this so long.
You could also mail me at prasad@pspindia.com which I would appreciate.
Thanks
Prasad
This is a common problem in most physics textbooks.
Essentially, you vector sum the forces acting on the container to 0, since the container is not accelerating (please, no general relativity). There are two forces acting on the container: the force of gravity F_g = mg and the buoyancy force F_B = \rho V g. Since they must vector cancel, set the two forces equal and solve for the mass m.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
