Calculate the change of angular velocity
The discussion revolves around calculating the change of angular velocity in the context of demonstrating conservation of angular momentum. Participants explore whether it is possible to determine the new angular velocity of a rotating system based solely on initial data and the distance that two masses are moved along the radius.
  • One participant asks how to calculate the change of angular velocity when moving masses in a rotating system and whether this can be done with initial data and the distance traveled by the masses.
  • Another participant expresses confusion about the scenario and requests clarification on the specifics of the rotations and masses involved.
  • A later reply suggests that the participant likely has a specific apparatus in mind and outlines a method to calculate the final angular speed after moving the masses, emphasizing the importance of knowing the moment of inertia of the structure and the masses.
  • The same reply provides formulas for calculating the moment of inertia and the conservation of angular momentum, indicating that the final angular velocity can be derived from these relationships.
  • One participant acknowledges the clarity of the explanation provided in the later reply, indicating it has helped them understand the topic better.
There is no clear consensus on the initial question, as some participants express confusion about the scenario while others attempt to clarify and provide a method for calculation. The discussion remains somewhat unresolved regarding the specifics of the initial conditions and the calculations involved.
Participants have not provided specific details about the apparatus or the exact parameters of the rotating system, which may limit the clarity of the discussion. Additionally, assumptions about the moment of inertia and the arrangement of masses are not fully defined.
SpaceThoughts
Hi there ...
How do I calculate the change of angular velocity, when demonstrating conservation of angular momentum?
I mean the change of angular velocity depends on the ratio between the two (rotating) masses that moves a distance along radius, and the (rotating) mass of the system itself.
In other words, if I know all the data about a rotating system before the change, could I possible figure out everything about the system after the changes just by knowing the distance traveled by the masses that moves along radius?
Is this at all possible to calculate?
I am not at university level, and would appreciate an easy to understand answer.
SpaceThoughts said:
Summary:: How do I calculate the change of angular velocity, when demonstrating conservation of angular momentum.
Just by knowing all the start data plus the distance traveled by the masses that moves along radius?
Hi there ...
Could you describe the scenario you have in mind? What you've written doesn't make a lot of sense to me.
When for example someone is demonstrating the conservation of angular momentum, switching between two different rotations. If I only know the data of the one rotation scenario, and decide a distance to move the masses along radius, will I then be able to calculate the new resulting rotation? With respect to the ratio between the mass of the system itself versus the mass of the two masses moved along radius.
I can't follow that, I'm sorry to say. What rotations, what masses, what radius? What new resulting rotation?
You apparently have a specific piece of demonstration equipment in mind, but we are not understanding what this equipment looks like or what you are doing with it. Could you post a diagram and ask your question using the diagram as a reference?
That being said, it sounds like you have an apparatus consisting of a rotating structure and two masses on the rotating structure. While the device is spinning the two masses can be moved inward or outward closer to or further away from the axis of rotation. If I am understanding correctly, you want to know how to calculate the final angular speed after moving the masses given the initial speed and some knowledge of the moment of inertia of the structure and the mass of the weights.
If I have that right, this should be a very simple calculation. You will need to know the moment of inertia of the structure. Usually this is a simple disk shape so that the inertia is easily calculated, or it is provided by the manufacturer of the demonstration equipment. Moments of inertia add, so with the added masses the total moment of inertia is:
##I_{struct} + m_1 r_1^2 + m_2 r_2^2 ##
Often the masses have the same mass and are arranged so that they are always at the same distance from the axis. Then the inertia reduces to
##I_{struct} + 2 m r^2##
The position of the masses r is what you are changing, and this in turn changes the moment of Inertia
##I_{initial} = I_{struct} + 2 m r_{initial}^2##
Is changed to
##I_{final} = I_{struct} + 2 m r_{final}^2##
Assuming negligible friction, momentum is conserved:
##I_{initial} {\omega}_{initial}= I_{final} {\omega}_{final}##
This is a really fine answer. Thanks a lot, it moves me forward ...
  • · Replies 30 ·
  • · Replies 19 ·
  • · Replies 16 ·
