Calculate the discharge between two pipes
  • Thread starter Thread starter amjid1709
    Discharge Pipes
This discussion focuses on calculating the discharge between two pipes with diameters of 250mm and 300mm, connected between two reservoirs with a 25-meter height difference. The key formula involves the velocities in the pipes, specifically (V1 - V2) squared, where V1 is the velocity in the upper pipe and V2 is the velocity in the lower pipe. The participants clarify that V1 can be expressed as 1.44 times V2, and they emphasize the importance of incorporating head losses into the Bernoulli equation to accurately determine the discharge and head losses along the pipeline.
  • Understanding of fluid dynamics principles, specifically Bernoulli's equation.
  • Knowledge of head loss calculations due to friction and sudden expansions.
  • Familiarity with pipe flow velocity calculations and relationships.
  • Ability to apply hydraulic gradient concepts in fluid systems.
  • Study the application of Bernoulli's equation in fluid mechanics.
  • Learn about head loss calculations in pipe systems, including minor and major losses.
  • Research the effects of pipe diameter changes on flow velocity and discharge rates.
  • Explore practical examples of hydraulic gradient and total energy line sketches in fluid systems.
Engineers, hydraulic designers, and students studying fluid mechanics who need to understand discharge calculations and head loss in pipe systems.
amjid1709
Hi,
I have a question, it is related to flows between two resorvoirs where I need to calculate the discharge between two pipes, with different pipe diameters.
The problem I have come across is where there is an expansion in the pipe size from 250mm diameter to 300mm, the formula states that I need to use is (V1 - V2) squared does anyone know what this means.
I am certain its velocity in pipe 1 minus pipe two but how to I calculate this?
Anyone?
amjid1709 said:
Hi,
Anyone?
Hi amjid1709,
Can you provide a drawing or sketch of your setup?
CS
Two reservoirs have a difference of 25 metres in water levels, a pipe line which of 125m long overall joins them. The upper 75m of the pipeline is 250mm diameter and the lower 50m is 300mm diameter. Local losses at entry and exit are of the form kv2/2g and K has the following values: at entry, 0.5; at exit, 1.0. At the sudden expansion v1 minus V2 squared where v1 is the velocity in the upper pipe and v2 is the velocity in the lower pipe. The friction factor is 0.028 for the upper pipe and 0.018 for the lower pipe.
Determine the rate of discharge from one reservoir to the other. Determine also the head losses along the pipeline and sketch the hydraulic gradient and total energy line.
To get the velocities in the pipes
V1 = 300/250 squared which = 1.44
if you square 1.44 you get V2 = 2.0376
and then to calculate the losess this is the method that was followed:
Entry pipe = 0.5 * 2.0376 = 1.0368
Upper pipe 0.028 * 75/ 0.025 * 2.0376 = 17.4182
Expansion V1 - V2 squared the answer I have been given is 0.44 squared which =0.1936
but I don't know how to get the answer to 0.44, I can do the rest of the calculations just this has snookered me, I bet its something easy but I just can't see it.
Any help would be appreciated.
i don't think you get the correct V1 and V2.
“V1 = 300/250 squared which = 1.44
if you square 1.44 you get V2 = 2.0376 “ (300/250)^2 you get the ratio of V1 to V2, not V1. so V1-V2=1.44V2-V2=0.44V2
I still don't understand I have tried your workings but still can't figure it out can you elaborate please.
amjid1709: You would need to write the Bernoulli energy balance equation, including the head losses, then solve for v1 or v2. The head loss due to a sudden expansion is he = (0.5/g)(v1 - v2)^2.
I am able to do that at the end when all head losses have been calculated the problem I'm having is where there is the sudden expansion in the pipe how do I calculate the losses at this point.
The formula given is V1 - V2 divde by 2 times gravity which is 9.81 x 2, I don't know how to do this part.
Can you help.
You can't compute the head losses until you solve for the velocity. The head losses are a function of velocity. Include expressions for the head losses in the Bernoulli equation, then solve for v1 or v2. Is this a school assignment?
To get the velocities in the pipes I did as follows
I know that I need to divde these by 2 x gravity at the end but the next step is to calculate the loss at the expansion.
Sorry but I really don't know what to do with the expansion in the pipe
amjid1709: v1 = 1.44*v2. Therefore, if you square v1, you get 2.0736*v2^2, not 2.0376*v2^2.
The head loss due to a sudden expansion is he = (0.5/g)(v1 - v2)^2. In your case, v1 = 1.44*v2; therefore, he = (0.5/g)(1.44*v2 - v2)^2 = 0.1936(v2^2)/(2*g).
Write your Bernoulli equation from reservoir 1 to reservoir 2. The kinetic energy (velocity head) in each reservoir is zero; therefore, we can omit those two terms from the Bernoulli equation. Assuming the pipeline entrance and exit are at the same depth below each reservoir surface, the pressure head is equal in reservoirs 1 and 2, and thus cancels out of the Bernoulli equation. This leaves you with the following Bernoulli equation, where h1 = reservoir 1 elevation head relative to reservoir 2, hL = major and minor head losses, ki = inlet head loss coefficient, ko = outlet head loss coefficient, f1 and f2 are your friction factors given in post 3, and the head losses (multiplied by 2*g) are listed sequentially from beginning to end of the pipeline. Solve for v2.
h1 = hL,
where (2*g)*hL = ki*v1^2 + f1*L1*(v1^2)/D1 + 0.1936*v2^2 + f2*L2*(v2^2)/D2 + ko*v2^2.
no need for me to elaberate, nuv has done it
  • · Replies 31 ·
