ssj
- 36
- 0
So the length L must be 0.5 and this means we must 0.5/2 because of L/2 correct?
Yes.ssj said:Right to in problem 1 we basically made it perpendicular correct ?
If you're talking about problem 1, that should be:So for now let's call the length L meaning that 200*L=200*T*sin30,
Using the corrected equation, we get: T = 200/sin30 = 400 N. The L drops out and has no bearing on the answer for tension. If the beam were twice as long, you'd still get the same tension.sin30 because that will give use the hypotenues which is T but the problem with the formula is that it gives the same answer as we got in question 1 meaning we must divide sin30 on each side meaning 200*L/sin30= 400 and once we find out the L we will get an new answer perhaps.
The right side is correct, but the left is not. Don't guess! You have two forces producing clockwise torques--add up the torque from each. You should know the torque from each one, since they are the same forces as appeared earlier.ssj said:My guess is something like 400*L/4=L*T*sin30
Doc Al said:The right side is correct, but the left is not. Don't guess! You have two forces producing clockwise torques--add up the torque from each. You should know the torque from each one, since they are the same forces as appeared earlier.
Doc Al said:Those were the tensions, not the torques. The clockwise torque from problem 1 was 200*L; from problem 2 it was 200*L/2.
Doc Al said:No:
200*L + 200*L/2 = 200*(3L/2)
This is not the equilibrium equation, this is just the sum of the clockwise torques (see post #43): 200*L + 200*(L/2) = 200*(3L/2) = 300*Lssj said:How did you get "3L/2" on the right hand side and why isit L/2 on the left side ? Furthure more once I calcualted this euqation L=200 where do I go from here?
Doc Al said:This is not the equilibrium equation, this is just the sum of the clockwise torques (see post #43): 200*L + 200*(L/2) = 200*(3L/2) = 300*L
Now set this sum of clockwise torques equal to the counter-clockwise torque due to the tension to the get the equilibrium equation:
300*L = L*T*sin30
Now you can solve for the tension in problem 3.
L + L/2 = 3L/2ssj said:For the sum of the clockwise torques I understand that 200*L+200(L/2) but I don't understand 200*(3L/2) where did the "3L" come from ?
Doc Al said:L + L/2 = 3L/2
You can also write that as: (3/2)*L
You can also do this:
200*L + 200*(L/2) = 200*L + 100*L = 300*L
Please convince yourself that these are equivalent.
The left-hand side (which represents clockwise torques) is correct--it's the same as the last problem. But the right-hand side is not correct. The angle is not the only thing that changes: the distance to the pivot point also changes--it's not L anymore.ssj said:I would think the answer is 300*L=L*T*Sin50 .
Doc Al said:The left-hand side (which represents clockwise torques) is correct--it's the same as the last problem. But the right-hand side is not correct. The angle is not the only thing that changes: the distance to the pivot point also changes--it's not L anymore.
Doc Al said:You now have the correct distance on the right-hand side (L/2), but what happened to the angle?
Right so the equation now becomes 300*L=L/2*T*Sin50.Doc Al said:Good! (I thought so.)
Doc Al said:Yep.
