Calculate Torque for Pin: L=100.9 cm, M=3.98 kg, m=537 g.
  • Thread starter Thread starter PoPrOcKsRoCk
    Pin Torque
The discussion centers on calculating the torque exerted by a pin to prevent a rod from rotating, given specific measurements: length (L=100.9 cm), mass of the rod (M=3.98 kg), and mass of the hanging weight (m=537 g). The relevant equation used is Torque = distance from the pivot * force. The solution involves calculating the torque from both the rod and the hanging mass, treating the rod's mass as concentrated at its center. The total torque is the sum of the individual torques from the rod and the weight.
  • Understanding of basic physics concepts, particularly torque.
  • Familiarity with the equation Torque = distance from the pivot * force.
  • Knowledge of how to calculate gravitational force (weight = mass * gravity).
  • Ability to analyze static equilibrium in physics problems.
  • Learn how to calculate torque in various scenarios using different pivot points.
  • Study the principles of static equilibrium in physics.
  • Explore the concept of center of mass and its application in torque calculations.
  • Investigate real-world applications of torque in engineering and mechanics.
Students studying physics, particularly those focusing on mechanics, as well as educators seeking to enhance their understanding of torque calculations in static systems.
PoPrOcKsRoCk
Torque of a pin. Please Help!
How much torque must the pin exert to keep the rod from rotating? (L=100.9 cm, M=3.98 kg, m=537 g.)
I attached the picture of the problem. I am unsure how to approach the problem. I am looking through my College Physics and cannot find an equation to solve this problem. Help please!
Torque=distance from the pivot*the force
Welcome to Physics Forums.
Okay, so based on that equation how much torque do the bar and hanging mass each exert on the pivot point (pin location)?
You may treat the bar's mass as being located at the bar's center.
I got it.
I used the equation T=Fr for the Torque of rod M and the Torque of the weight of m then added both torques.
Thank you.
  • · Replies 17 ·
  • · Replies 21 ·
  • · Replies 22 ·
