Calculate voltage drop by using kirchoff's law
To calculate the voltage drop across the 8-ohm resistor in a series circuit with a 30V battery and resistors of 8 ohms, 2 ohms, and 4 ohms, Ohm's Law (V = I * R) is applied. The correct current through the circuit is determined to be 2.142 Amps. Multiplying this current by the resistance of the 8-ohm resistor yields a voltage drop of 17.136V across it. The total voltage drops across all resistors will equal the supply voltage of 30V, with larger resistors dropping more voltage proportionally to their resistance. This illustrates the application of Kirchhoff's law in analyzing voltage drops in series circuits.
Arno@praxispc
The circuit has a battery Voltage of 30V, a resistor of R1(8ohms), R2 (2Ohms) and R3 (4ohms) in series. Calculate the voltage drop over R1
Please give me the proper equation of this? The one I've got says you take 30-8I-2I-4I=0
Wich gives you current of 2.142 and not the voltage.
Now what i tried doing is this.
30V-8-2-4=0
30V=14
V=14/30
V=0.466
but I'm sure its wrong.
You have the correct current, although you could just add the resistor values up using mental arithmetic and work out the current using Ohm's Law.
This current flows through an 8 ohm resistor, so what is the voltage across the resistor?
ok so what you are saying is that if i use ohms law V=I*R
I will have to use the 8 ohm resistor times by the current of 2.142= 17.136V
Is this the voltage after it went through the resistor or is this the amount of voltage drop?
The voltage across a resistor is equal to the current through it times the resistance of that resistor.
So, the 8 ohm resistor times the current of 2.142 Amps = 17.136 Volts.
If you do this for all the resistors, you will see that they add up to the supply voltage of 30 volts.
You should also see that the bigger resistors drop more of the the available voltage than the smaller ones, exactly in proportion to their resistance.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
