RedRook
- Messages
- 22
- Reaction score
- 0
Another way of finding torque at the wheel at top speed is looking at power of the forces resisting acceleration. I have to get to work, so I'll just say that the equations for A and C that you posted in the other thread are exactly what I think is correct. You can replace CRR with a more general coefficient that represents the overall friction rather than just rolling friction, and the power loss from this friction should be directly related to speed. You normally have the top speed posted. The drag coefficient is normally posted, and if you can't find the frontal area affected, one approximation equation I see floating around using a modern car's height and width from the front is:
[itex]Area = ((H * W)/4)^2 * \pi[/itex]
Top Speed = [itex]\sqrt[3]{P_M / 2A+\sqrt[2]{(P_M / 2A)^2+(C/3A)^3}}+\sqrt[3]{P_M / 2A-\sqrt[2]{(P_M / 2A)^2+(C/3A)^3}}[/itex]
Those two equations combined should let you come up with your more generalized coefficient of friction. Then the power of the drag + the power of the friction should roughly equal the power at the engine. The power of drag alone should roughly equal the power being put out by the wheels, and the torques at the wheels can be determined by figuring out RPM's that will be determined by tire diameter that could lead to your force output at the wheels. Also keep in mind that a tire measured in milimeters and rim size measured in inches has a diameter equation of:
(((Width * (Aspect Ratio / 100) * 2)/25.4) + Rim size
The 25.4 comes from the millimeters in an inch. You'll likely have to play with this number depending on what units your tire width and rims diameter are measured. Those are simply the units I'm used to. Basically this is all based on the idea that acceleration stops when the power of resisting forces equals the power of accelerating forces. I have to get to work have fun.
