Calculating Acceleration of a Flywheel Driven by a Pulley System
The discussion revolves around calculating the acceleration of a flywheel driven by a pulley system, with specific parameters including a braking force, moment of inertia, and forces acting on the pulley belt. Participants are exploring the implications of the given values and the relationships between torque, force, and acceleration.
  • Mixed
  • Participants discuss various equations related to torque and angular acceleration, questioning the application of forces and the interpretation of the braking force. There is uncertainty about the correct use of the forces from the pulley system and how to account for friction.
Several participants are attempting to clarify the relationships between the forces and torques involved, with some expressing confusion over the units and definitions used in the problem. There is an ongoing debate about the interpretation of the braking force and its role in the calculations, with no clear consensus reached.
Participants note potential typos in the problem statement regarding the nature of the braking force, leading to discussions about the validity of the problem as presented. Some express that their understanding is based on guidance from tutors, while others emphasize the need for clarity in the problem's wording.
r4vr4c
A flywheel is driven by a pulley system. friction in the system exerts a braking force of 2Nm. The moment of inertia is 400kgm2.
The forces in the pulley belt are 120N on the tight side and 80N on the slack side.
Pulley diameter is 0.2m
Calculate the acceleration of the wheel.
the pulley has the greater diameter but doesn't say the diameter of the motor but doesn't give a diameter for the motor. also doesn't say which way the flywheel is moving.
I have made several attempts using equations like the square root of I/m but i don't know the mass. i did 400/120 which i think gives me the radius of gyration. but as i already know the inertia i don't then thought i don't need this.
so i then did T= F x R
But as I'm not sure which is the side with the pulley i just guessed that it was the bigger force of 120N
120/0.1 = 1200Nm
T=I x a
a= T/I
1200/400 = 3rad/s2
or is the using the other 80N
or is it using the 80N and then subtracting the 1st from the second?
how does the 2N of braking force get accounted for?
You wrote,
"so i then did T= F x R
120/0.1 = 1200Nm"
Why did you divide by the radius? Don't you want to multiply by r? Also there are three torques in this problem, the torque from friction and the two torques from the belt?
Well Torque is equal to inertia multiplied by alpha and as alpha is the acceleration which i need to find out.
I have pages and pages of equations and workings out ranging from using omega to mechanical advantage but it would take a long time to write it all down.. obviously as i don't know the answer and me doing 120/0.1 is a mistake.
as i only have one radius how can i work out the torque running through the other side of the system? I am given forces along the belt but it doesn't state which are for what.
I am on here for help else i wouldn't have posted and your clearly not helping
You wrote,
"I am on here for help else i wouldn't have posted and your clearly not helping"
Not my intention.
I may be mistaken but,
You wrote,
"120/0.1 = 1200Nm"
I thought the 120 above was 120N and the 0.1 above was .1m ? If so when you divide above you don't get Nm?
don't get huffy - you divided where you should have multiplied to solve the equation torque = F cross R
It's the sum of the torques that is equal to I alpha and the torque in this case will be the sum of the forces from the pulleys minus force due to friction if they are all acting on the same radius. My problem with questions of this sort is that not every physics student is a gear head and knows what a flywheel is and how it works, what the slack side does and what the tight side does so you best option here is to google or go to wikipedia flywheel and look at how one works. From there, sum your forces, if they all act on the same radius, to get your net torques and then use your torque = I alpha from there just as you are doing. So your problem is not being able to visualize the system. Lucky you has google or wikipedia or a gear head friend.
i think i'v got it now.. i took the 80N and 120N and subtracted them together to give me the net force which i then multiplied by the radius of 0.1m to give me 4Nm i then added the friction to give me 6Nm.
From there i used the equation T=Ialpha and rearranged so alpha = T/I
6/400 = alpha (angular acceleration)
which gives 0.015 rad/s
This to me sounds small but it does seem like the right way of going around it and getting to the answer
You do have one problem with the original equation though - it say the braking force is 2Nm. Forces don't come in Nm. IF it's supposed to read a braking force produces a negative torque on the system of 2Nm you'd be OK but it doesn't say that. Also why would you ADD the braking force/torque to the torque moving the system? also check your units on alpha - acceleration comes in rad/sec squared
well a breaking force is a negative force.. and i added it as it needs to have xNm to accelerate the wheel but also needs an extra 2Nm force to overcome the friction
2 Nm is NOT a force. It is a torque. You need to check with your teacher on this. If it is a braking torque then yes you can subtract it but the problem says it is a FORCE which it is NOT because of the units Nm. This is an error in the problem.
yeah i did check with the tutor who said what i had done was right
The problem is incorrect, not you. It should have state that a torque caused by friction is 2 NM, not that there is a force of friction of 2 NM. Forces don't come in Newton meters, they come in Newtons.
yes I'm not disagreeing with you but as the solution i have got is correct why are you going any further with it? i know it should be Nm but its a typo
Because whoever wrote the problem needs to fix it. Even though you got the "right" answer according to whatever source gave you the answer, you really didn't didn't solve this problem because it is not solvable as written. Their proof reader didn't catch this mistake and it's the better student who will get penalized because they would know it wasn't solvable. Just a good thing to know. You probably know that on the SAT and the GRE, I'm thinking, you can appeal a question and it will get fixed.
well the tutor of the class gave me the answer and how to solve it.. I'm not even studying mechanics. its all just additional knowledge that i asked for to broaden my knowledge. I'm studying electrical engineering. What is SAT and GRE? I'm from the uk not the states
Scholastic aptitude test to get into college and Graduate Record Exam to get into graduate school in the US.
Regardless, the problem itself has a "fatal flaw" and at least you know about it.
well those exams are invalid to me as i live in the uk lol.. I'm taking foundation to electrical engineering degree so like i say this has nothing to do with the course I'm studying just for own personal knowledge.. thank you for pointing out the mistake though
True, but a lot of people from the UK do study in the US at some time in their educational careers so it's good to know about the tests. You can buy books with practice tests in them just to see how well you would do, "for personal knowledge". The GRE also has specific course tests like physics, chemistry, and so on. They are pretty wicked. One of the universities I attended actually required a major in EE to get a physics major. As I had no interest in that area, I did transfer to a different university. :-)
Good luck!
28K
  • · Replies 22 ·
  • · Replies 30 ·
