Calculating Area from Differentials
5 replies · 2K views · last reply
ardentmed
Hey guys,
I need some more help for this problem set I've been working on. I'm doubting some of my answers and I'd appreciate some help.
This is only for question 2. Ignore 1.
Question:
Alright, so from drawing a diagram, we know that width is "L" and length is "3L." Moreover, the area of the circle uses 1/2 * L for the radius.
Thus,
A = 3L^2 + $\pi$.5L^2 / 2
Thus, using differentials, we know that:
f(a+$\Delta$x) = f(a) + $\Delta$y
And
$\Delta$y = f'(x) $\Delta$x
From substituting $\Delta$y into the other equation, we get:
f(8.05) = 200.99734.
Thus,
A(8.05) = 200.99734 cm^2
For the percent error, it should be $/delta$A / A * 100 = 1.37%.
I'm not too sure about my answer though, particularly the area I calculated via differentials. What do you guys think?
Thanks in advance.
Hi, ardentmed
Thankyou so much for sharing your problem with us at the MHB:)
First, the way you use the differentials is in principle OK, but I cannot
from the explicit area function see if you have stated it right. Parentheses are needed:
\[A(L) = 3L^2+\frac{1}{2}\pi \left ( \frac{L}{2}\right )^2=3L^2+\frac{1}{8}\pi L^2= \left ( 3+\frac{\pi }{8} \right )L^2\]
Do you agree so far?
lfdahl said:
Hi, ardentmed
Thank you for being so helpful.
Yes, that seems correct. Then how would I proceed with this question?
Next step would be to use the formula you have derived by means of differentials:
$\frac{\Delta A}{A(L)}\approx\frac{A'(L) \cdot \Delta L}{A(L)}\cdot 100 \%$
So you need to determine the derivative of $A$.
Alright, so I used the following formula:
And substituted 8 for L, and used A(L)= 3L^2 + (1/8)$\pi$ L^2
and
A'(L)= 6L + (1/4)$\pi$L
And ultimately computed the following:
=0.694489677 * 100
~ 6.94%.
Is that correct?
Thanks again for the help.
and
=0.694489677 * 100
~ 6.94%.
Is that correct?
Hi, again.
Your procedure is perfectly right. Good job! But I think you´ve made a computational error. I get: $1.25 \%$
The computation can be made quite simple, if you let $k = 3+ \frac{\pi}{8}$.
Then: $A(L) = kL^2$ and $A'(L) = 2kL$
and $\frac{A'(L)\Delta L}{A(L)}=\frac{2kL \Delta L}{kL^2}=\frac{2 \Delta L}{L}=\frac{2\cdot0.05}{8}= 0.0125=1.25 \%$
