Calculating average from probabilistic measurements?
mkbh_10
I have got a sample size of 1000 and I calculated the mean probability of success of an event by breaking this sample size into sets of 50 and also have the standard deviation and standard error of mean of this success.
Now I repeat this process and have another set of data.
What will be the process of calculating the average of the probability and the error?
The setup is:
You have done an experiment of n(=50) identical trials which you repeat m(=20) times getting N=nm(=1000) trials.
In each experiment you have s successes, so the probability of a success in each experiment is estimated as: p=s/n or something like that?
This gives you n slightly different values for p - a "distribution" - from which you can find a mean and a standard deviation.
You do this again ... getting another mean and standard deviation from the new distribution of p values.
Now you are wondering how to combine the two distributions?
That about it?
Hi all, I've been a roulette player for more than 10 years (although I took time off here and there) and it's only now that I'm trying to understand the physics of the game. Basically my strategy in roulette is to divide the wheel roughly into two halves (let's call them A and B). My theory is that in roulette there will invariably be variance. In other words, if A comes up 5 times in a row, B will be due to come up soon. However I have been proven wrong many times, and I have seen some...
Thread 'Detail of Diagonalization Lemma'
The following is more or less taken from page 6 of C. Smorynski's "Self-Reference and Modal Logic". (Springer, 1985) (I couldn't get raised brackets to indicate codification (Gödel numbering), so I use a box. The overline is assigning a name. The detail I would like clarification on is in the second step in the last line, where we have an m-overlined, and we substitute the expression for m. Are we saying that the name of a coded term is the same as the coded term? Thanks in advance.
