Calculating Capacitance of LC Circuit
5 replies · 7K views
omer10000
Calculate capacitance of LC Circuit where:
Inductor - 30H
Capacitance voltage fully charged goes to zero in 20 seconds
Main Eq: V=V. *cost(ωt) where V is final Voltage, V. = Voltage initial, ω = resonant angular frequency
ω = 1/√(LC) = 2∏f
f. = 1/2∏√(LC) --> resonance frequency
Calculated f=1/80 =0.0125Hz as voltage of capacitor takes 20s to deplete 1/4 cycle
∴ ω = 2∏*0.0125=0.0785
Rearranged angular frequency equation to solve for C
∴C=1/(ω^2 * L) = 5.404F
Since Voltage = 0 after t = 20s = 1/3min,
V=V. *cost(ωt)
0=V.*cos(0.0785*(1/3))
Since the whole equation is multiplication, calculating V. would not be required since if cos equaled 0 then so would the whole right hand side of the equation. However cos equals close to 1 and therefore I'm stuck.
Please help
Thank you
Edit: Thread has been answered and I'm correcting my mistake for those reading this post as a reference on how to answer this type of question. Mistake was in the calculation of main equation:
V=V.*cost(ωt)
0=V.*cos(0.0785rad/s*20s) --> Calculate using radian mode on calculator
0=V.*0.00
0=0 --> as anything multiplied by 0 is equal to 0
Answering main question of this thread...
Capacitance = 5.404 Farards
gneill said:
Check your calculator for degrees versus radians setting.
Hi,
I checked by calculating cos in radians and degrees but both equal a figure close to one but i need it to equal zero.
Thank you
omer10000 said:
Hi,
Thank you
Your ω is in units of radians per second. Your time should be specified in seconds, not fractions of a minute.
Alright I got it.
V=V.*cos(ωt)
0=V.cos(0.0785rad/s * 20s)
0=V.*0.001=V.*0
0=0
Thanks for the help gneill, I suppose the above therefore is correct.
Answering the main question of this thread;
Capacitance = 5.404 Farads
Thank you
