Calculating Change in Energy: A Graph Analysis
RandiSS
A gas expands from I to F in the figure. The energy added to the gas by heat is 486 J when the gas goes from I to F along the diagonal path.
1. What is the change in internal energy of the gas?
Answer in units of J.
2. How much energy must be added to the gas by heat for the indirect path IAF to give the same change in internal energy? Answer in units of J.
ΔU = Q + W
W=pΔV
Not a solution. This is the graph provided.
P-V graph of a thermodynamic cycle with points I, A, F and B; I at P=4 atm, V=0.5 L; A at P=4 atm, V=3 L; F and B at P=2 atm, F at V=3 L; arrows show I to A to F, I to B to F, and a diagonal I to F.
I think I start with finding the magnitude of the IF vector but I’m not sure. And I don’t know where to go from there.
Alternatively, apply the first law for the direct path IF. You are given the heat added QIF and you are looking for the change in internal energy ΔUIF. Can you find WIF from the graph? Note that your relevant equation should be ΔW=pΔV.
Hey I got it figured out. Thanks for the help. :)
