Calculating Critical Angles for Sliding Blocks on Ramps
  • Thread starter Thread starter cellfoneguy
    Angles
The discussion revolves around calculating the critical angle for a block sliding down a ramp, considering the mass of the block and the coefficient of friction between the ramp and the block. Participants are exploring the relationship between gravitational forces and frictional forces in this context.
  • Participants are attempting to derive the critical angle by analyzing the forces acting on the block, including gravitational and frictional forces. Questions arise about the setup of equations and the role of the normal force in this scenario.
There is an ongoing exploration of the relationships between the forces involved, with some participants providing insights into the components of gravitational force and friction. Multiple interpretations of the critical angle and its derivation are being discussed, with no explicit consensus reached yet.
Participants note constraints such as the availability of only two variables (g and mu) and express confusion about how to incorporate mass into their calculations. The discussion reflects a lack of complete information regarding the derivation process for the critical angle.
cellfoneguy
No specific question.
How would one find the critical angle of a ramp given the mass of the block sliding down it and the mu between ramp and block?
It's not a single question but something my teacher explained that i didn't understand.
F=(mu)mg
F=ma
I'm not sure of any more
I just don't get how to calculate the critical angle.
Is there a formula or a way to derive some equations?
What i know is i have to get the gravity vector that points down the ramp to exceed friction.
But how would i set up that equation?
The critical angle is that angle at which component of g along the inclined plane is equal to the acceleration due to frictional force.
Can you write the expression for frictional force?
Wouldn't the vector of gravity along the ramp have to exceed the friction for it to move? If it were equal, then the block would be stationary, right?
Frictionforce=(mu)mg
Frictionforce=(mu)normalforce
Also thanks for the quick reply.
Do you know what a Free Body Diagram is? Split up the components of the objects weight and set them equal to the opposite forces. Remember that cosine is horizontal while sine is vertical.
The block will move with uniform velocity.
Now what is the expression for the normal force?
The component of g along the inclined plane is g*sin(θ) where θ is the critical angle of the inclined plane with the horizontal.
Now I'm confused.
The normal force is pointing perpendicular to the ramp, right?
Why would i need that?
And for the g vector along the ramp, i need to find the critical angle, so how could i use it in an equation, unless i can cancel it somehow?
If you resolve g into two components, g*sinθ is along the inclined plane and g*cosθ is perpendicular to the ramp, which is thew normal force.
At critical angle g*sinθ = μ*g*cosθ.
Hmm, ok.
However, for now i only have 2 of those 3 variables, g, and mu.
If i wanted to get theta equals something, what i got from deriving is
sin(theta)/cos(theta)=mu.
So now what do i do?
I have sin and cos on one side, so would i take cos^-1(mu)/sin^-1 ?
Or what...
Also, how would the mass come into play?
Sorry, i researched a little and found that sin/cos =tan.
I got it now, thanks so much rl.bhat!
again.
  • · Replies 32 ·
  • · Replies 16 ·
