Calculating dψ2/dx and d2ψ2/dx2
  • Thread starter Thread starter dawozel
13 replies · 3K views
dawozel
ψ2 = A(2αx2- 1)e-αx2/2
First, calculate dψ2/dx, using A for A, x for x, and a for α.
Second, calculate d2ψ2/dx2.
3. The Attempt at a Solution
so I got the first derivative correct, it was
A((4*a*x)*exp((-a*x^2)/2) +(2*a*x^2 -1)*(-a*x*exp((-a*x^2)/2)))
but i can seem to calculate the second derivative correctly I'm getting
A((4*a)*(exp((-ax^2)/2)) + (4*a*x)*(-a*x*exp((-ax^2)/2)) +(4*a*x)*(-a*x*exp((-ax^2)/2)) +(2*a*x^2 -1)*(a^2*x^2*exp((-ax^2)/2)))
but this incorrect, am I missing something?
This is just about impossible to read. I could take a guess at what you're trying to say, but I shouldn't have to. Take a look at this, especially #2: https://www.physicsforums.com/showthread.php?t=617567.
My bad this is the second derivative
[itex]A((4a)(exp(( - ax^2 ) / 2)) + (4ax) * ( - ax * exp(( - ax^2) /2)) + (4ax) * ( - a xexp(( - ax^2 ) / 2)) + (2ax - 1) (a^2x^2 *exp(( - ax^2 ) / 2)))[/itex]
[itex]A((4a)(exp(( - ax^2 ) / 2)) + (4ax) * ( - ax * exp(( - ax^2) /2))[/itex]
[itex]+ (4ax) * ( - a xexp(( - ax^2 ) / 2)) + (2ax - 1) (a^2x^2 *exp(( - ax^2 ) / 2)))[/itex]
That's a lot better.
Is this ψ2?
Here's what you have, cleaned up a little more, using more LaTeX and fewer parentheses.
$$A((4a)(e^{ - (a/2)x^2}) + (4ax) * ( - ax * e^{-(a/2)x^2}) + (4ax) * ( - a xe^{- (a/2)x^2}) + (2ax - 1) (a^2x^2 *e^{- (a/2)x^2}) $$
This ought to be at least close to what you have.
Take a look at your last term, and consider the Product Rule. You missed something.
This is the first derivative, correct?
##A[4axe^{-ax^2/2}+(2ax^2-1)(-axe^{-ax^2/2})]##
If so, in your computation of the second derivative, you need to perform a product rule within a product rule.
So my first derivative was simplified to [itex]\frac{d}{dx}\psi_2(x)=A\left[4\alpha x e^{-\frac{1}{2}\alpha x^2} - (2\alpha x^2 - 1)\alpha x e^{-\frac{1}{2}\alpha x^2}\right][/itex]
and if i factor out the [itex]\alpha x \exp(-\frac{1}{2}\alpha x^2)[/itex]
i get that
[itex]\frac{d}{dx}\psi_2(x) = A(\alpha x \exp(-\frac{1}{2}\alpha x^2))(5-2ax^2)[/itex]
so my second derivative should be
[itex]A(((aexp((-1/2)ax^2) + (-a^2x^2exp((-1/2)ax^2)) +(4ax))[/itex]
is this right?
i get that
Looks good to me. Can you differentiate that now?
is this right or am i still missing a product rule?
Still missing a bit. Try doing this in two steps. Let ##f(x) = \alpha x \exp(-\frac{1}{2}\alpha x^2)## and ##g(x) = 5-2ax^2##
What is the derivative of ##\frac{d}{dx}\psi_2(x) = Af(x)g(x)##? (simple application of product rule)
After that, calulate ##f'(x)## and ##g'(x)## and then plug everything into the the second derivative formula you got.
I know this is a lot of tedious work but I hope you'll be able to see why you were leaving out the terms you did.
Hmmmm i may be forgetting to multiply the [itex]F' (x) by G(x)[/itex] and vice versa
Is the derivative closer to
[itex]A((((aexp((-1/2)ax^2) + (-a^2x^2exp((-1/2)ax^2))(5-2ax^2) + (4ax)( \alpha x \exp(-\frac{1}{2}\alpha x^2))[/itex]
That looks better. You were just forgetting to put in that very last term. One minor issue with a sign error, the derivative of ##5-2\alpha x^2## is ##-4\alpha x## so you need a minus sign in the one place.
And there's a bunch of parentheses; I'll just assume that they line up correctly. Just double check them if you are submitting them for homework.
