Calculating dψ2/dx and d2ψ2/dx2
  • Thread starter Thread starter dawozel
The discussion revolves around calculating the first and second derivatives of the function ψ2 = A(2αx² - 1)e^(-αx²/2). Participants are exploring the steps involved in differentiation, particularly focusing on the application of the product rule in their calculations.
  • Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss their attempts at calculating the first and second derivatives, with some expressing confusion about their results and the application of the product rule. Questions arise about specific terms in the derivatives and whether certain steps have been overlooked.
There is an ongoing examination of the calculations, with some participants providing guidance on the correct application of differentiation rules. Multiple interpretations of the derivatives are being explored, and while there is no explicit consensus, suggestions for refining the calculations have been made.
Participants are working under the constraints of homework rules, which may limit the amount of direct assistance they can receive. There is also a focus on ensuring clarity in the mathematical expressions used in the discussion.
dawozel
ψ2 = A(2αx2- 1)e-αx2/2
First, calculate dψ2/dx, using A for A, x for x, and a for α.
Second, calculate d2ψ2/dx2.
3. The Attempt at a Solution
so I got the first derivative correct, it was
A((4*a*x)*exp((-a*x^2)/2) +(2*a*x^2 -1)*(-a*x*exp((-a*x^2)/2)))
but i can seem to calculate the second derivative correctly I'm getting
A((4*a)*(exp((-ax^2)/2)) + (4*a*x)*(-a*x*exp((-ax^2)/2)) +(4*a*x)*(-a*x*exp((-ax^2)/2)) +(2*a*x^2 -1)*(a^2*x^2*exp((-ax^2)/2)))
but this incorrect, am I missing something?
This is just about impossible to read. I could take a guess at what you're trying to say, but I shouldn't have to. Take a look at this, especially #2: https://www.physicsforums.com/showthread.php?t=617567.
My bad this is the second derivative
[itex]A((4a)(exp(( - ax^2 ) / 2)) + (4ax) * ( - ax * exp(( - ax^2) /2)) + (4ax) * ( - a xexp(( - ax^2 ) / 2)) + (2ax - 1) (a^2x^2 *exp(( - ax^2 ) / 2)))[/itex]
[itex]A((4a)(exp(( - ax^2 ) / 2)) + (4ax) * ( - ax * exp(( - ax^2) /2))[/itex]
[itex]+ (4ax) * ( - a xexp(( - ax^2 ) / 2)) + (2ax - 1) (a^2x^2 *exp(( - ax^2 ) / 2)))[/itex]
That's a lot better.
Is this ψ2?
Here's what you have, cleaned up a little more, using more LaTeX and fewer parentheses.
$$A((4a)(e^{ - (a/2)x^2}) + (4ax) * ( - ax * e^{-(a/2)x^2}) + (4ax) * ( - a xe^{- (a/2)x^2}) + (2ax - 1) (a^2x^2 *e^{- (a/2)x^2}) $$
This ought to be at least close to what you have.
Take a look at your last term, and consider the Product Rule. You missed something.
This is the first derivative, correct?
##A[4axe^{-ax^2/2}+(2ax^2-1)(-axe^{-ax^2/2})]##
If so, in your computation of the second derivative, you need to perform a product rule within a product rule.
yes that's my first derivative
So my first derivative was simplified to [itex]\frac{d}{dx}\psi_2(x)=A\left[4\alpha x e^{-\frac{1}{2}\alpha x^2} - (2\alpha x^2 - 1)\alpha x e^{-\frac{1}{2}\alpha x^2}\right][/itex]
and if i factor out the [itex]\alpha x \exp(-\frac{1}{2}\alpha x^2)[/itex]
i get that
[itex]\frac{d}{dx}\psi_2(x) = A(\alpha x \exp(-\frac{1}{2}\alpha x^2))(5-2ax^2)[/itex]
so my second derivative should be
[itex]A(((aexp((-1/2)ax^2) + (-a^2x^2exp((-1/2)ax^2)) +(4ax))[/itex]
is this right?
i get that
Looks good to me. Can you differentiate that now?
is this right or am i still missing a product rule?
Still missing a bit. Try doing this in two steps. Let ##f(x) = \alpha x \exp(-\frac{1}{2}\alpha x^2)## and ##g(x) = 5-2ax^2##
What is the derivative of ##\frac{d}{dx}\psi_2(x) = Af(x)g(x)##? (simple application of product rule)
After that, calulate ##f'(x)## and ##g'(x)## and then plug everything into the the second derivative formula you got.
I know this is a lot of tedious work but I hope you'll be able to see why you were leaving out the terms you did.
Hmmmm i may be forgetting to multiply the [itex]F' (x) by G(x)[/itex] and vice versa
Is the derivative closer to
[itex]A((((aexp((-1/2)ax^2) + (-a^2x^2exp((-1/2)ax^2))(5-2ax^2) + (4ax)( \alpha x \exp(-\frac{1}{2}\alpha x^2))[/itex]
That looks better. You were just forgetting to put in that very last term. One minor issue with a sign error, the derivative of ##5-2\alpha x^2## is ##-4\alpha x## so you need a minus sign in the one place.
And there's a bunch of parentheses; I'll just assume that they line up correctly. Just double check them if you are submitting them for homework.
Thanks for your help sir!
  • · Replies 47 ·
