Calculating Electric Field for 2 Test Charges
1 reply · 36K views · last reply
jprforester
Two test charges are located in the x–y plane. If q1 = -2.75 nC and is located at x = 0.00 m, y = 0.800 m and the second test charge has magnitude of q2 = 3.20 nC and is located at x = 1.00 m, y = 0.400 m,
calculate the x and y components, Ex and Ey, of the electric field, , in component form at the origin, (0,0). The Coulomb Force constant is 1/(4*pi*ε) = 8.99 × 10^9 N·m^2/C^2
given:
q1 = -2.75 nC; x = 0.00 m, y = 0.800 m
q2 = 3.20 nC; x = 1.00 m, y = 0.400 m
E=kq/r^2
So what I did was take the q1 and q2 values (given in nC) and convert them to C.
Next I took found the distance from the origin of the two points, solved using the E=kq/r^2 for each point where k=8.99e+9.
I found the components of the E1 (has only j component) and E2 (by solving the angle from the origin using tan^-1(y-distance/x-distance) and multiplying that by the E2 value)
then I added the two vectors together but still do not get the right answer.
I Calculated:
q1 = -2.75e-9 C
q2 = 3.20e-9 C
r1 = .8
r2 = sqrt(1^2 + .4^2) = 1.077
theta = tan^-1(.4/1) = 21.8 deg
I solved the equation
so E1 = -38.6 j (N/C)
and |E2| = 24.8 N/C => separate into components
E2 = 23.03 i + 9.21 j (N/C)
thus Ex = 23.03 N/C
Ey = -15.6 N/C
Welcome to PF,
Basically, the directions of your components are wrong.
In vector form, the electric field of a charge q is $$\mathbf{E} = \frac{kq}{r^2}\mathbf{\hat{r}}$$Boldface quantities represent vectors, and the unit vector ##\mathbf{\hat{r}}## is a unit vector that points "radially outward" (i.e. away from the charge that is the source of the field). The vector ##-\mathbf{\hat{r}}## points towards the charge that is the source of the field. Unlike the Cartesian unit vectors ##\mathbf{\hat{i}}##, ##\mathbf{\hat{j}}##, and ##\mathbf{\hat{k}}##, whose directions are fixed, the direction of ##\mathbf{\hat{r}}## varies depending on where you are in space. In the case where you're located at the origin, and the source of the field, q1, is located on the y-axis at (0,0.8), the radial unit vector, which points away from the source charge and towards the location where you are evaluating the field, is in the ##-\mathbf{\hat{j}}## direction (i.e. ##\mathbf{\hat{r}}## = ##-\mathbf{\hat{j}}## in this particular case). HOWEVER because q1 is negative, this negative sign cancels out the one on the ##\mathbf{\hat{j}}##, and the E-field ends up pointing in the positive ##\mathbf{\hat{j}}## direction. So E1 is directed upwards along the y-axis, towards the charge q1. This make sense, because q1 is negative, so a positive test charge placed at the origin would be attracted up towards it.
Using a similar argument, you can reason that the x and y components of E2 should be in the ##-\mathbf{\hat{i}}## and ##-\mathbf{\hat{j}}## directions respectively (again, because ##\mathbf{\hat{r}}## points away from q2 and towards the origin, and q2 is positive this time).
