Calculating Equivalent Resistance in a Hexagonal Prism Circuit
41 replies · 13K views
gneill said:
The correct one :smile:
I'm not sure it's the right time yet to give away the answer.
I did the same you did ...
So your answer is 33R/28 ?
Nope. A bit smaller.
smaller than 1.7R ?
Here's how i solved ... Bold black lines are the resistances
What happened to the resistances ab, cd, a'b', c'd' ?
there won't be any current through them right? so we can just remove them. Is that wrong ?:confused:
I don't think that you can assume that there will be no current through them.
gneill said:
Sure. I've only labeled some of the resistances, the rest should be obvious by color code and symmetry.
Did you get 17R/16?
Abdul Quadeer said:
Did you get 17R/16?
Nope. A bit too small.
Here's the next step in the simplification. The diagram is still symmetrical, so the Delta-Y transformations at either end will be the same...
Yup. That's what I had & did.
I got it - 23R/20
Thanks!
Abdul Quadeer said:
I got it - 23R/20
Thanks!
Yes, that's it. Attached is the summary of the simplifications used.
