Calculating Force/Moment to Bend Strip into Circle
  • Thread starter Thread starter stressdave
    Bend Circle
The discussion revolves around calculating the force or moment required to bend a thin steel strip into a circular shape, specifically for stowage on the ISS. Participants explore various factors influencing the bending process, including material properties, dimensions, and potential long-term effects such as creep or permanent curvature.
  • Some participants emphasize the importance of material properties, cross-section dimensions, and the circle diameter in determining the required force or moment for bending.
  • One participant describes a specific scenario involving a 192-inch long steel strip that is formed into a 21-inch circle for stowage, questioning the potential for creep or set over 15 years.
  • Another participant suggests that the maximum stress in the stored configuration should be calculated and compared to a stress creep curve for the material.
  • Some participants express uncertainty about the theoretical determination of the bending force, noting that common experience indicates that a coiled strip may show residual curvature when uncoiled.
  • There are discussions about the potential for permanent curvature due to metallurgical changes and stress relaxation, with some suggesting that creep may not be a significant factor under the given conditions.
  • One participant proposes using the limit state method to estimate an upper bound on the bending force required.
  • Questions arise regarding the minimum coil wrap diameter to avoid yielding the metal, with some participants seeking clarification on stress calculations in the stored state.
Participants do not reach a consensus on the exact force required to bend the strip or the implications of long-term storage. Multiple competing views on the effects of stress, creep, and permanent curvature remain present throughout the discussion.
Limitations include the dependence on specific material properties and environmental conditions, as well as the complexity of accurately modeling the bending process and its long-term effects.
stressdave
I need to calculate the force or moment required to bend a thin strip into a circle
Depends on the material properties , the material cross section dimensions , the circle diameter , the means of forming the curvature and the amount of spring back that is acceptable .
Please tell me what you are actually trying to do .
Thanks for the reply. I have a 192 inch long steel strip of very low stiffness. We form it into a circle by hand and attach ends with fasteners. It is stowed by twisting it into a circle of 21 inches for stowage on the ISS. The question has been asked is what amount, if any, or creep, or set, will occur over 15 years. I don't think anything will change and the yield point is not reached. It is analogous to a windshield sun screen. Total spring back is required.
That's a hard problem to answer . I'll have to think about it .
What is the specific steel specification and the strip thickness ?
It sounds like you don't actually need the force, but instead need to calculate the maximum stress on the part in the stored configuration, and compare that force to a stress creep curve for the material it's made out of.
https://en.wikipedia.org/wiki/Creep_(deformation)
use strain gages to see whether the material is with in elastic limit.
Pro tem I can't see a way of deciding this matter theoretically .
Though the solution seems obvious common experience suggests that initially straight thin strip coiled up for a long time almost always shows some residual curvature when uncoiled again .
I know some of the mechanisms involved in this but putting the whole thing together to get numerical answers is likely to be problematic .
You certainly want to keep stress levels in the coiled strip very low ( ideally < 10% Yield Stress ) and if possible do an accelerated ageing test .
The method is to design the part to stay below the material's creep strength in the stored configuration. Creep strength commonly depends on temperature and a few other things, but it's possible to design for 99.9% spring back with the appropriate material.
It is spring steel per ASTM A313. The thickness is only .053 inch. The part is stowed in 70 deg F environment. I can't image creep will occur.
With your moderate temperatures and low stress levels I don't think that creep would be an active mechanism causing permanent curvature .
Permanent curvature could possibly be caused under these conditions by metallurgical changes and stress relaxation but best guess based on available information is that there is unlikely to be any significant problem . The strip could possibly have a slight permanent curvature but so little as to be unimportant .
Remember in any case that a thin strip can never be entirely straight under normal circumstances .
Thanks again
Let me rephrase the question. How much force would it take to bend a strip of very stiffness 360 degrees around a 20 inch mandrel? The length of strip would be approximately 67 inches.
That's kind of a tough question actually, most typical beam bending equations assume small deflections and so won't apply to this situation. Have you done any testing up to this point?
You can use the limit state method to get an upper bound on the bending force .
I am not familiar with the limit state method. Let me ask a new question. What is the recommended coil wrap diameter of a .053 inch thick x .345 inch wide steel strip that will not yield the metal?
What would be the minimum coil wrap diameter of this strip stock?
Is there a minimum coil wrap diameter to avoid yield?
You have to keep the stress below the creep strength of the material, which will be lower than the yield strength. You need to first calculate the stress/strain for the ring in the "stored" state and see where you are. Do you have the stress calculation?
