How Does the Force to Start and Maintain Car Movement on Asphalt Differ?
To start moving a car weighing 1500 N on dry asphalt, a force of 1800 N is required due to the static friction coefficient of 1.2. Once the car is in motion, a lower force of 1440 N is needed to maintain movement, calculated using the kinetic friction coefficient of 0.8. The difference in forces is attributed to the higher resistance of static friction compared to kinetic friction. The calculations clarify that more force is necessary to initiate movement than to sustain it. Understanding these frictional forces is crucial for vehicle dynamics on asphalt.
BarCode
A car of weight 1500 N has its brakes locked. Calculate the force needed to begin to drag he car on dry asphalt. How will the force needd to slide it along the asphalt compare with the force needed to start sliding it? Why? (Static coefficient=1.2, Kinetic coefficient=0.8)
Known: weight (1500 N, the mass in N on earth) , coefficients of static and kinetic friction
Ff = (coefficient of kinetic)(normal force)
Fn = mg
(force needed to start it moving)
Force of friction = 1.2 * 1500 N
= 1800N
(force needed to keep it moving)
= Force of friction * coefficient Kinetic friction
= 1800N * 0.8
= 1440N
Now that I have these numbers, I do not know what to write to answer the questions that are asked.
I don't understand why you did 1800*0.8 for the second part. Should it not be 1500*0.8?
Ffr=uFN
These numbers tell you that you need a greater force to get the car sliding than you need to keep it sliding.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
