Calculating force we need to turn
  • Thread starter Thread starter k1mJo
    Force
5 replies · 2K views
k1mJo
Hello
I have a cylinder that diameter is 60 mm,length is 500 mm and this is approximately 11 kg .If i want to move the cylinder,how much force do i need to move?
How i calculate this kind of cylinders?
are you rolling it? or is it sliding on it's circular face? what material is it being pushed on?
yes,it is being rolled and if u want to learn about friction value,it doesn't matter.
well, if no friction, and perfectly flat surface, I don't think you need very much force at all. it's so precariously balanced on a hard line, that it should fall forward (roll) at the slightest push.
rolling resistance is your weight (lbs or Newtons(kgs*9.81)) multiplied by your rolling resistance coeff. If no rolling resistance coefficient than no force to overcome that roll.
Thanx huntoon :), you say that we use this formula ( F=m.a) .
I didn't say that. I said the force you need to roll something is it's weight * its rolling resistance coeff.
