Calculating Force with Mass and Acceleration
The discussion focuses on calculating net force using mass and acceleration, with a specific example of 36.1 grams and 1.36 m/s². The calculated net force is verified as 49.1 milliNewtons when rounded to three significant figures. A follow-up question addresses the calculation of force of resistance using an equation that incorporates angle, leading to different results for two angles (10.4 and 11.24 degrees). The discrepancy in results is attributed to the subtraction of similar values in the second calculation. Clarification on the setup of the problem is suggested to ensure the accuracy of the force of resistance calculation.
socialfox
Mass= 36.1 (Grams)
Acceleration = 1.36 M/S(sqaured)
Net Force in MiliNewtons =
Fnet= MA
Fnet= 0.0361 x 1.36
= 0.049096 Newtons
0.049096 x 1000= 49.096 MiliNewtons
Can anyone verify this for me please?
Hi, socialfox.
Your work look's good. (Picky: If the problem is stated with 3 significant figures for each quantity, then generally you would round your answer to three significant figures: 49.1 mN.
Also, "milli" has two l's.
Thank you for replying, I had another question with that information I was supposed to calculate the force of resistance with this equation:
9.8(Mass)(Sin*angle*) - (m)(a)
so I had filled it in with these numbers below (the angle is 10.4 degrees)
9.8(36.1)(sin10.4) - 49.096 = 14.768 MilliNewtons
I understand this answer seems normal but for another question with simmilar numbers except for the degrees which is now 11.24 degrees I get this
9.8(36.1)(sin11.24) - 68.951 = 0.000749325 MilliNewtons
My problem/doubt is why is my second answer so different, also is the force of resistance correct for these questions?
Thanks for taking the time to look over this, I appreciate it :)
Your calculations look correct. However, I think it would be more consistent if you plug in SI units (.0361 kg) for the mass and then convert Newtons to milliNewtons. But' you'll get the same result.
The results seem so different because in the last case you happen to be subtracting two terms that have almost the same value.
It's hard for me to say if your "force of resistance is correct" since I don't know the set-up of the problem. Maybe you could explain how you arrived at the expression mgsinθ - ma.
  • · Replies 17 ·
  • · Replies 24 ·
  • · Replies 38 ·
