Calculating Friction in Pin Joints for Linkages | Homework Help
  • Thread starter Thread starter cs003
    Friction Pin
The discussion revolves around calculating the friction in pin joints for linkages, focusing on how to apply the frictional force equation in this context. The scope includes homework help and conceptual understanding of friction in mechanical systems.
  • Homework-related, Conceptual clarification
  • One participant states the equation for frictional force as F="mu"*N and expresses uncertainty about its application to a pin joint.
  • The same participant assumes a "loose fitting" pin, suggesting that friction is limited to a point on the surface and questions if the applied force can be used as N in the equation.
  • Another participant, despite being in their first year, agrees that the logic presented seems reasonable based on their lecture notes.
  • A follow-up post seeks confirmation that the initial reasoning is not overlooking any major aspects, emphasizing the need for a rough estimate of friction.
Participants generally agree that the initial logic regarding the application of the friction equation is reasonable, but there is no consensus on the specifics of the approach or any potential oversights.
There may be limitations regarding the assumptions made about the pin joint's fit and the applicability of the friction equation in this specific mechanical context.
Students studying mechanics, particularly those interested in friction in mechanical linkages and pin joints.
cs003
I'm trying to determine the friction of a pin joint that will be loaded differently depending on the position of the linkage.
I know the equation for frictional force is F="mu"*N, where "mu" is either the coefficient of static or kinetic friction depending on if the surface is in motion, but I'm not sure how to apply that to a pin joint.
Im assuming the pin to be "loose fitting" so that friction will be basically limited to a point on the surface. And if I know the force applied to the joint, can I just take that force as N in the equation and and find the appropriate "mu" to solve for the frictional force? I'm just looking for a decent approximation for the friction.
Since there have been no respones, should I assume that my logic is reasonable? Or just nobody has a decent idea about it either?
Any input would be appreciated.
Thanks.
Only in 1st year, but that logic sounds right based on my lecture notes
Thanks.
I'm really just looking for a rough estimate of friction, but I was mainly looking for input just to make sure I wasn't overlooking something too major.
  • · Replies 102 ·
