Calculating Inductance of Toroid Core - Tips & Formula
  • Thread starter Thread starter ElectroJohnny
    Inductance Toroid
Calculating the inductance of a toroidal core requires specific parameters, including inner and outer diameter, height, wire radius, number of turns, and core permeability. The user seeks a comprehensive formula that incorporates these factors, as existing resources do not meet their needs. It's noted that wire diameter minimally impacts inductance if the required turns fit within the air gap, while frequency and temperature significantly affect core permeability. For accurate calculations, obtaining the manufacturer's datasheet for the core material is recommended. The user is working on a DC-DC converter and needs to determine the necessary inductance based on the provided specifications.
ElectroJohnny
Hello, I need help with calculating inductance of a toroid core. I tried googling and came up with 3 results, but they don't really help. Links are:
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/indtor.html
http://www.nessengr.com/techdata/toroid/toroid.html
http://www.phys.uri.edu/~gerhard/PHY204/tsl267.pdf
The information I have:
Toroid inner diameter: 8 mm
Toroid outside diameter: 15 mm
Toroid height: 6 mm
Wire radius: 0.63 mm
Number of turns: 60
I need a formula that takes into consideration inside and outside diameter (or radius), height, wire radius, number of turns and permeability of the core. None of the formulas in above links seem to do that.
Thanks in advance.
The first link above tells you how to come up with the formula. This link carries it out
http://www.phys.ufl.edu/~acosta/phy2061/lectures/Inductance.pdf"
Thanks for link, I'll give it a read tomorrow (going to bed now). After that I'll ask further questions (if there are any). :)
You have some very good references already, but I have attached another one which gives some information about the uses of different types of toroid.
I found it on HamRadioIndia.org. Very well presented and hopefully accurate.
View attachment toroid_datasheet.pdf
Wire diameter doesn't have much effect on the inductance of a toroid as long as you can fit the required number of turns into the air gap.
Frequency does have a huge effect on some toroid materials. Permeability can drop to 10% of the low frequency value, or less.
So, it really needs to be measured or specified at the frequency you wish to use it at.
Also, temperature has a big effect and if stability is an issue (such as when making coils for oscillators) this should be considered.
Another useful document is this one:
http://www.fair-rite.com/newfair/pdf/Broadband.pdf
which deals with broadband transformers using ferrite materials.
Try to get the makers data sheet for the actual core you are using. Usually, their data is very thorough and helpful.
It is a bit of a black art, though, and eventually you have to put some wire on a ferrite and start measuring.
Many thanks guys, I'll give them a thorough read when I get back from college.
The thing is, I'm trying to make a DC-DC 12V/24V converter and the author of circuit I'm using hasn't specified inductance, but has given above information instead. There is no talk about permeability (i.e. specific material used for toroid) so I don't even know where to start to calculate needed inductance. :/ Any ideas?
Here's a direct quote from the author:
"L1 is made by winding 60 turns of 0.63MM magnet wire on a toroidial core measuring 15MM (OD) by 8MM (ID) by 6MM (H)."
what is the magnetic field outside the torroidal coil - ie in the centre and on the outside
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
