Calculating Joules from Capacitance: Answers & Tips
  • Thread starter Thread starter RED119
    Capacitance
The discussion revolves around calculating energy stored in capacitors and the implications of connecting them in parallel. A user initially calculated the energy from 18 capacitors but arrived at a significantly lower value than expected, prompting questions about the calculations. It was clarified that when capacitors are connected in parallel, they all share the same voltage, and their capacitance adds up, but the applied voltage must not exceed the lowest voltage rating among them to avoid damage. The formula for energy storage, E = 0.5 * C * V^2, was confirmed, with C representing capacitance. Proper understanding of voltage ratings and charge analysis is crucial for safe capacitor usage in circuits.
RED119
So I read a page where someone said they had put 18 400v 3900uF capacitors in parallel and that this came out to 5600 joules... Now I'm sure I am doing something wrong but when I did it out I only got 28.08 joules...
I used this website: http://www.rapidtables.com/calc/electric/Volt_to_Joule_Calculator.htm
plugged 400 in for volts and 0.0702 in for coulombs, if someone can let me know what I am doing wrong here please let me know.
Second little question, i know if you put capacitors in parallel you just add the Farads, but if they all have different volts, say one has 20v 3000F, the other has 400v 90uF, what would that end up being in parallel?
5600 J looks like the correct answer. Use: energy = CV2/2.
If you put the capacitors in parallel, by definition they will all assume a single voltage across all connected capacitors. The parallel capacitance is independent of the voltage.
[edit] Sorry--if you mean what is the resulting voltage, you have to do a charge analysis.
Thanks so much for the reply, is the C in that equation coulombs or capacitance?
Welcome. C is capacitance. 'q' is usually represents the charge.
hi ya'welcome to PF :)
just remember tho, you cannot mix voltage values ... that is, the applied voltage to the capacitors must not exceed the lowest rated capacitor voltage value
eg. as in your example of a 20V and a 400V cap, the circuit voltage shouldn't exceed 20V else that lower voltage rated capacitor will fail
but having a 50V, 100V etc rated cap in a 20V circuit isn't a problemDave
The voltage rating of a capacitor is the voltage that the capacitor can withstand before being destroyed. At this moment I forget whether that is peak or RMS voltage, but it is general practice to overrate capacitors in a circuit. So if one capacitor in a network of paralleled capacitors is rated 20 volts, you can't apply voltage greater than 20 volts without risking damage to the one rated at 20V.
