Calculating magnetic flux of a rod
The discussion revolves around calculating the electromotive force (EMF) and velocity related to magnetic flux in a rod. The given magnetic field strength, length of the rod, and angular velocity are used to derive solutions for two problems. The user explores two methods: one using electric principles and another involving an imaginary area to calculate magnetic flux. The main inquiry is about the validity of using an imaginary area to arrive at the same solution for both problems, despite the absence of a physical area in the scenario. Clarifications are sought on the underlying principles that justify this approach.
yahelra
B = 0.02T
L = 40 cm
w = 10 rad/s
a: Electromotive force between O and C = ?
b: If electromotive force is the same - so what is the velocity?
I found 2 ways of solution. See "3. The Attempt at a Solution "
φ = BA
ε = -dφ(t)/dt
So I found 2 ways:
1. What every one would do - by Electric:
2. By the magnetic flux. But wait - There is no area.
So I found that if I would take in problem a the area of what the rod had passed (part of a disc) I would get the exact solution.
For problem b if I would take the area of a triangle I will get the solution too.My question - Why does the second way is also true? How can it be explained (For both problem a and b)?
Thanks a lot!
Is that a line or a rod? The way the picture is presented it doesn't look like there is any flux, let alone a change in flux. Did you give us the entire problem statement?
I gave you the entire statement.
And you are right, as I wrote there are no magnetic flux because there is no area.
I meant that I've found that we can take an imaginary area and it will give us the same solution. ( See picture -0.016 V)
My questions are why is it true and how can it be explained?
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
