Calculating Minimum Stopping Distance for Truck & Box
The discussion focuses on calculating the minimum stopping distance for a truck to prevent a box from sliding, given a static friction coefficient of 0.39 and a truck speed of 87.8 km/hr. Participants express confusion about applying the correct equations, particularly the kinematic equation Vf^2 = V0^2 + 2a(delta x). One user initially miscalculates the stopping distance but later corrects it to 104.2 meters after realizing a mistake in squaring the initial velocity. Additionally, there is a related question about determining mass M1 in a pulley system, where users discuss the setup and equations but continue to face challenges in arriving at the correct answer. The thread highlights common pitfalls in physics calculations and the importance of careful equation application.
NAkid
The coefficent of static friction between the floor of a truck and a box resting on it is 0.39. The truck is traveling at 87.8 km/hr. What is the least distance in which the truck can stop and ensure that the box does not slide?
Fs=Us*N
I really am not sure how to work this out. I attempted using formula Vf^=V0^2 + 2adx but I don't think that's right. Help please!
Sorry, my other question is this:
M1 and M2 are two masses connected as shown. The pulley is light and frictionless. Find the mass M1, given that M2 (7.00kg) accelerates downwards at 3.43m/s2, that theta is 20.0o, and that muk is 0.390.
I'm pretty sure I set it up correctly:
for block 2 i said, T-mg=ma --> T=ma+mg
for block 1, T-fk-mgsin(theta)=ma AND N-mgcos(theta)=0 (no acceleration in vertical direction)
also, i know that m2>m1 for m2 to accelerate downwards
basically i plugged everything in but the answer is still wrong..
Fs=Us*N
I'm also having trouble with this problem. Here is what I tried (which didn't work):
First my numbers are different. Us=0.25 and v=81.4 km/hr.
First I converted 81.4 km/hr to 22.61 m/s.
Fs = Us*N => ma = Us*mg => a = Us*g => a = (0.25)(-9.81) = -2.4525 m/s^2
v^2 = v0^2 + 2a(delta x) => 0 = 22.61 + 2(-2.4525)(delta x) => delta x = 4.61 m
This is the wrong answer according to LONCAPA, so I don't really know what to do now.
You forgot to square the initial velocity in the second equation.
Oh simple mistakes... they kill me.
I have the right answer now... 104.2 m
I'm also having trouble with this one if anyone has any advice to offer.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
