Calculating Net Electric Field
To calculate the net electric field at x = 0cm from two charges, one positive (+8.36 mC) and one negative (-20.2 mC), the electric fields generated by each charge must be computed separately using the formula E = kq/r^2. The direction of the electric field must be considered, as it is defined by the force on a positive test charge, meaning the electric field from the negative charge will point towards it. The calculations yield E1 as approximately 1.0007E8 N/C and E2 as approximately -2.216E-7 N/C. The net electric field is then found by summing these values, resulting in a total of approximately 7.79E7 N/C. It is important to clarify that the charges provided in the problem are indeed the values to use for q in the calculations.
BornSurvivor
Two charges are placed on the x axis. One charge (q1 = +8.36mC (microC)) is at x1 = +2.74cm and the other (q2 = -20.2mC (microC)) is at x1 = +9.05cm. Calculate the net electric field at x = 0cm.
E= kq/r^2
I tried calculating the electric field at that point for both charges and then tried adding them together. There was another topic with a very similar question, and that is the solution that was reached, but it doesn't work for this problem.
It should work for this problem. One possible mistake: mC usually means milli-Coulombs, and \muC usually means micro-Coulombs
I think the mC meaning microC is just my weird homework interface.
When I calculate the individual electric fields, is q always positive? I know it is in Coulomb's Law calculations.
No, in Coulomb's law calculations, you only get the magnitude of the electric field. You must decide on what direction it is in. (Or you can use the full vector form of the Coulombic force, which tells you the direction).
EDIT: Well, I should have said yes, q is always positive, because then this gives the magnitude of the electric field. But I meant no, the electric field isn't always positive.
Ok, so
E1= http://www.texify.com/img/%5CLARGE%5C%21%288.987E9N/C%2A8.36E-6C%29/.0274%5E2m.gif
E1= 1.0007E8 N/C
E2= http://www.texify.com/img/%5CLARGE%5C%21%288.987E9N/C%2A20.2E-6C%29/.0905%5E2m.gif
E2= -2.216E-7 N/C
And Enet = E1+E2
Enet= 7.79E7N/C
But that wasn't right.
Am I correct using the two charges given in the problem as q? Or does q actually refer to a test charge I have to make up?
Edit: Oh, and I realize that N/C is not the unit for k, but that doesn't make a difference if I know the units for electric field.
E1 should be negative of what you've got. and E2 should be negative of what you've got. Remember, the electric field is defined as going in the direction that a positive test charge would be forced. And yes, q refers to the charges given in the problem.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 68 ·
