Calculating Projectile Velocity to Clear 11m Wall
The problem involves calculating the projectile motion of a rocket fired at a specific angle and speed to determine how much it clears an 11m high wall located 20m away. The subject area includes kinematics and projectile motion principles.
  • Participants discuss the relationship between horizontal and vertical motion, the use of velocity, distance, and time in calculations, and the need to find the time it takes for the rocket to travel horizontally. There are attempts to clarify the horizontal and vertical components of velocity and how they relate to the wall height.
Participants are actively engaging with the problem, exploring different aspects of projectile motion. Some have provided guidance on calculating horizontal velocity and time, while others are questioning their calculations and understanding of the relationships involved.
There are indications of confusion regarding the calculations, particularly in determining time and the relationship between horizontal and vertical components. Participants are also reflecting on their understanding of the problem setup and the implications of the wall height.
scw287
A rocket is fired at a speed of 75.0 m/s from ground level, at an angle of 66.4° above the horizontal. The rocket is fired toward an 11.0 m high wall, which is located 20.0 m away. The rocket attains its launch speed in a negligibly short period of time, after which its engines shut down and the rocket coasts. By how much does the rocket clear the top of the wall?
I'm really stuck on this question not positive on my work
-4.9 t^2 +75 t sin 66.4 +0
horizontal component 75*cos(66.4) and a vertical component (75*sin(66.4))
I don't know how you would find time
Consider the horizontal motion. You have the distance and velocity.
I know it relates to time...but I am not sure how to tie the two together
What's the simplest relationship between velocity, distance, and time?
What's the difference between vertical and horizontal motion for a projectile?
v=change x/change of time
the horizontal component doesn't have acceleration?
Exactly right on both. The horizontal component is constant speed motion: Distance = speed X time. What's the horizontal speed and distance traveled?
Horizontal speed:750m/s
Distance traveled:
Distance=speedXtime
29cos66.4=750m/sXtime<<?
The total velocity is only 75 m/s--find the x-component of that.
Distance traveled:
is given--no calculation needed.
oops i meant 75.0 m/s, would it be 29.0
That's close, but with a caculator you should be more accurate.
V_x = 75.0 m/s * cos(66.4 degrees) = ?
How does the 11.0 m wall come into play do i have to subtract it from 30.0262
Not yet, you've so far got the horizontal velocity (30.02). We're on to finding the time it takes to travel 20.0m (horizontally).
Then we can start on the vertical components.
so I would just multiply 30.02m/s*20m
V_y=75m/s*sin(66.4)
then I use the formula (V_y*t-9.80*t^2)/2
then subtract that answer from 11m right?<<<am I'm on the right track I just keep getting a very large numbers for answers
Not quite. Remember the relationship between velocity, time and distance?
Well i think i messed up on the time it should be .666 i think b/c of the formula v=change of x/change in time?
so if i calculated v_y right and t right my equation would be 68.727*.666+(-9.80m/s^2*(.666)^2)/(2)
YES I GOT IT THAT TIME! so i guess i have learned something today
  • · Replies 53 ·
  • · Replies 21 ·
