Calculating proper time using schwartzchild metric
The discussion focuses on calculating proper time for an observer at radius r0 using the Schwarzschild metric. The user attempts to find the proper time for a light beam traveling from r0 to r1 and back, initially struggling with the limits of integration. Suggestions include simplifying the integral by recognizing that the observer's proper time can be expressed in terms of coordinate time, leading to a straightforward integral. The key insight is that the light beam's worldline is null, which allows for a relationship between the coordinate time and the proper time. Ultimately, the user is advised to double the integral result to account for the round trip of the light beam.
demonelite123
I am using the schwartzchild metric given as ds^2 = (1 - \frac{2M}{r})dt^2 - (1 - \frac{2M}{r})^{-1} dr^2, where I assume the angular coordinates are constant for simplicity.
So if a beam of light travels from radius r0 to smaller radius r1, hits a mirror, and travels back to r0, I am trying to find how much proper time has passed for an observer fixed at r0. So far, i have that this path can be parametrized by r = r0 and t = x, where x is just my parameter. Therefore, r' = 0 and t' = 1. Using the formula for arc length, i have that the proper time is given by \int \sqrt{1 - \frac{2M}{r_0}} dx.
this is where i am stuck as i am having trouble determining the limits of my integral. can someone give me a hint or two in the right direction? thanks
Your integrand doesn't have any variable in it. The r_0 shouldn't be inside the integral; it should relate to a limit of integration.
You could try setting ds^2=0 and then separating variables and integrating to get a relation between r and t for the light beam.
First of all, you don't really need the extra parameter x; as far as the observer fixed at r0 is concerned, he's just traveling from t0, the time when he emits the light beam, to t1, the time when it returns to him. So you could just write the integral as:
\tau = \int_{t_{0}}^{t_{1}} \sqrt{1 - \frac{2M}{r_{0}}} dt
But the integrand doesn't depend on t, so you can just factor it out, and that makes the integral trivial:
\tau = \sqrt{1 - \frac{2M}{r_{0}}} \left( t_{1} - t_{0} \right)
Which, of course, should make you realize that the real focus of the problem is determining the coordinate time interval t1 - t0. The way to do that is to focus, not on the worldline of the observer fixed at r0, but on the worldline of the light beam. There are two segments to it (the one from r0 inward to r1, and the one from r1 back outward to r0), but they are mirror images, so to speak, so they should take equal coordinate time to traverse. So figuring out the coordinate time for one is sufficient. That's where I would recommend focusing your efforts. The key fact you need, in addition to what you've already posted, is that the light beam's worldline is null; that is, the interval ds^2 along the light beam's worldline is zero.
Well, the way I'd approach it is this:
Integrating along the path that the light takes won't give us the right answer - we want to integrate along the path that the clock takes between transmission and reception. Which is a simple path, of constant r = r0.
So we need to draw a space-time diagram with the ingoing light beam, and the outgoing lightbeam. How do we do this?
Given the line element
ds^2 = (1 - \frac{2M}{r})dt^2 - (1 - \frac{2M}{r})^{-1} dr^2p
we know that for a light beam, ds = 0. This immediately gives us the ratio dr/dt for the light beam - which will be a function of r.
So we'll have f(r) dr = dt, where I'm too lazy to write out f(r).
Integrating this we'll get \Delta t=F(r). We'll have the same \Delta t on the ingoing and outgoing null geodesic - so we double it.
This will give us the coordinate time that elapses between emission and reception. To get the proper time, we integrate along the worldline at r=r0 between the emission and reception events. dr=0 for this intergal, so we get a simple time dilation factor
ds = \int \sqrt{1 - \frac{2M}{r}} \, dt = \sqrt{1 - \frac{2M}{r}} \Delta t
ok so setting ds^2 = 0, i get (1 - \frac{2M}{r})dt^2 = (1 - \frac{2M}{r})^{-1} dr^2 or dt^2 = (1 - \frac{2M}{r})^{-2} dr^2. then taking the square root of both sides, i get dt = (1 - \frac{2M}{r})^{-1} dr.
now i can integrate both sides and i get t_1 - t_0 = \int_{r_1}^{r_0} \frac{r}{r - 2M}dr = (r_0 - r_1) + 2Mln(r_0 - 2M) - 2Mln(r_1 - 2M).
would this be correct? thanks for you replies.
As noted before, to get the final answer you need to multiply the result by 2 because the integral you have given gives the "one-way" time, and you need the "round trip" time. The integral itself looks OK to me.
In an inertial frame of reference (IFR), there are two fixed points, A and B, which share an entangled state $$ \frac{1}{\sqrt{2}}(|0>_A|1>_B+|1>_A|0>_B) $$ At point A, a measurement is made. The state then collapses to $$ |a>_A|b>_B, \{a,b\}=\{0,1\} $$ We assume that A has the state ##|a>_A## and B has ##|b>_B## simultaneously, i.e., when their synchronized clocks both read time T However, in other inertial frames, due to the relativity of simultaneity, the moment when B has ##|b>_B##...
  • · Replies 31 ·
  • · Replies 17 ·
