Calculating Sound Intensity and Pressure Variation at a Distance
The problem involves calculating sound intensity and pressure variation from a speaker emitting music at a specified power. It requires determining the sound intensity level in decibels at a distance, the maximum pressure variation, and the distance for a specific intensity level, given certain physical parameters of air.
  • Participants discuss the application of equations for sound intensity and decibel levels. The original poster attempts to calculate intensity using the provided power and distance but encounters uncertainty regarding the reference intensity value.
Some participants have provided guidance on the reference intensity value, with one confirming the use of a standard value corresponding to the threshold of hearing. The discussion is exploring the origin of this reference value and its relevance to the calculations.
There is mention of specific parameters such as temperature, pressure, molar mass, and heat capacity ratio, which may influence the calculations but are not fully explored in the discussion.
Ian Baughman
A speaker blares out music with a power of 10 W. Assuming the air has a temperature of 50°F and a pressure of 1 atm, what is the sound intensity level in decibels at a distance of 100m away? What is the maximum pressure variation at that point? What is the distance at which the intensity is 50 dB? The air has an effective molar mass M = 28.8 g and a ratio of heat capacities γ = 1.40.
[/B]
1) I = P/(4πr2)
2) β = (10 dB)log(I/I0)
1) I used equation #1 where P = 10 W and r = 100 m to find:
I = 7.96 ×10-5 W/m2
2) This is where I'm having difficulty. I'm not quite sure on how to find I0. I know I can't use the above equation but I can't seem to find any other information that would be helpful.
I0 is a standard value of intensity that should be given in your textbook or notes.
So I found a value, I0 = 10-12 W/m2. Where does this value come from though?
Thank you!
