Calculating Speed in Simple Harmonic Motion
asuslinux
[SOLVED] Simple Harmonic Motion
This is the question I was given on my assignment, I can't seem to get it, bad prof so I am trying to teach all of this to myself, but this stuff is a bit confusing. From what I have tried and gather from examples in mt text, sub in .120s and solve but that is not working.
The position of a mass that is oscillating on a spring is given by (14.0cm)cos[(18.0s^-1)t].
What is the speed of the mass when t = 0.120 s?
Also, I don't think 18.0s^-1 is angular speed, I think its frequency but the book has nothing in it about it, got that from google.
I am looking for a step in the right direction in solving this one, the equation I am using are:
v = -wAsin(wt + theta)
The solution I am getting is -13.4 m/s which is not right, any help would be great. Thanks.
Can you show how you got the -13.4 m/s? Are you working in radian mode on your calculator?
Yeah, I am working in radian mode, this is going under what I was assuming the 18.0s^-1 is frequency so I converted it using:
w = f2(pi)
and then used that in the velocity equation, I don't think that's right, but just using the 18 as w doesn't work either.
I think the 18 s^-1 is the angular speed. Can you show what answer you get when you use 18?
V = -(18 * .14)sin(18 * .120)
= -(2.52)sin(2.16)
= -(2.52)(.83138)
= -2.095 m/s
That answer is not right either.
Yeah, I got it after, I was forgetting speed is a scaler so leaving out the negative solved the problem, thanks for your help.
