Calculating Speed in Simple Harmonic Motion
The discussion revolves around calculating the speed of a mass in simple harmonic motion, given the position equation and time. The position is defined as (14.0 cm)cos[(18.0 s^-1)t], and the user initially struggles with the correct interpretation of angular speed versus frequency. The correct formula for speed in this context is v = -wAsin(wt), where w is the angular speed. After some back-and-forth, the user realizes that the negative sign in the velocity calculation indicates direction, and the speed should be considered as a scalar value. Ultimately, the confusion is resolved, leading to the correct interpretation of the problem.
asuslinux
[SOLVED] Simple Harmonic Motion
This is the question I was given on my assignment, I can't seem to get it, bad prof so I am trying to teach all of this to myself, but this stuff is a bit confusing. From what I have tried and gather from examples in mt text, sub in .120s and solve but that is not working.
The position of a mass that is oscillating on a spring is given by (14.0cm)cos[(18.0s^-1)t].
What is the speed of the mass when t = 0.120 s?
Also, I don't think 18.0s^-1 is angular speed, I think its frequency but the book has nothing in it about it, got that from google.
I am looking for a step in the right direction in solving this one, the equation I am using are:
v = -wAsin(wt + theta)
The solution I am getting is -13.4 m/s which is not right, any help would be great. Thanks.
Can you show how you got the -13.4 m/s? Are you working in radian mode on your calculator?
Yeah, I am working in radian mode, this is going under what I was assuming the 18.0s^-1 is frequency so I converted it using:
w = f2(pi)
and then used that in the velocity equation, I don't think that's right, but just using the 18 as w doesn't work either.
I think the 18 s^-1 is the angular speed. Can you show what answer you get when you use 18?
V = -(18 * .14)sin(18 * .120)
= -(2.52)sin(2.16)
= -(2.52)(.83138)
= -2.095 m/s
That answer is not right either.
Yeah, I got it after, I was forgetting speed is a scaler so leaving out the negative solved the problem, thanks for your help.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
