Calculating Stationary Points of a Function
  • Thread starter Thread starter Hart
    Function Points
13 replies · 6K views
Hart
Finding the stationary point(s) of the function:
[tex]f(x,y) = xy - \frac{y^{3}}{3}[/tex]
.. on the line defined by [itex]x+y = -1[/itex].
For each point, state whether it is a minimum or maximum.
.. within the problem statement and solutions.
This is what I have so far:
[tex]g(x,y) = x+y-1 = 0[/tex]
Therefore need to extemise:
[tex]F(x,y,\lambda) = f + \lambda g = xy - \frac{y^{3}}{3} + \lambda(x+y-1)[/tex]
So calculating the partial derivatives:
[tex]\frac{\partial F}{\partial x} = y + \lambda = 0[/tex]
[tex]\frac{\partial F}{\partial y} = x - 3\left(\frac{y^{2}}{3}\right) + \lambda = x - y^{2} + \lambda = 0[/tex]
[tex]\frac{\partial F}{\partial \lambda} = x + y - 1 = 0[/tex]
Then need to look for all consistent solutions:
[tex]1. y = \lambda[/tex]
.. but now I'm stuck on what to do now, seemto have done something wrong because I can't get more consistent soluations and then nice simultaneous equations to equate :confused:
OK.. So from the first partial derivative equation I get that:
[tex]y = -\lambda[/tex]
.. then put this into the second partial derivative equation, which gives:
[tex]x - \lambda^{2} + \lambda = 0[/tex]
.. hence:
[tex]x = \lambda^{2} - \lambda[/tex]
.. then put this into the third partial derivative equation, which gives:
[tex]\lambda^{2} - \lambda - \lambda - 1 = \lambda^{2} - 2\lambda - 1 = 0[/tex]
.. then solve quadratic equation to get values of [itex]\lambda[/itex]:
[tex]\lambda = \frac{2 \pm \sqrt{(4) + (4)}}{2} = 1 \pm \sqrt{2}[/tex]
.. hence:
[tex]\lambda = 1 + \sqrt{2} , 1 - \sqrt{2}[/tex]
.. yes??!
.. note: but:
[tex]\lambda = 1 \pm \sqrt{2} \neq - y[/tex]
:confused:
um.. nothing! I don't know why I thought there was an issue there earlier! :redface: .. maybe just going a bit mad! :wink:
Right, so since now have:
[tex]y = -1 - \sqrt{2}, x = 2 + \sqrt{2}[/tex]
[tex]y = -1 + \sqrt{2}, x = 2 - \sqrt{2}[/tex]
.. then there are just 2 stationary points of the function, which are those 2 above?
Also, to find if the points are maxima or minima, just need to put each set of [itex](x,y)[/itex] values into this equation:
.. and if [itex]f(x,y) > 0[/itex] then maxima point, and if [itex]f(x,y) < 0[/itex] then minima point?
(why do you keep going into LaTeX?!)
No, that only tells you the value of f(x,y) …
you'll need more than that to check whether the value is a local maximum or minimum or stationary point.
.. calculate second derivatives? negative = max point, positive = min point?
Hi Hart! :smile:
(just got up :zzz: …)
Yes, except you'll need the second derivatives "dot" the line. :wink:
erm.. so for the first set of values I have:
[tex]f(x,y) = xy - \left(\frac{y^{3}}{3}\right) = \left(\left(2+\sqrt{2}\right)\left(-1-\sqrt{2}\right)\right) - \left(\frac{\left(-1 - \sqrt{2}\right)}{3}\right) = \left(-4 - 3\sqrt{2}\right) - \left(-7 + 5\sqrt{2}\right) = 3 + 2\sqrt{2}[/tex]
which is positive, so this is a minium stationary point.
.. correct?!
OH.. I just forgot them! :redface:
ok, so:
[tex]f(x,y) = xy - \left(\frac{y^{3}}{3}\right)[/tex]
[tex]\frac{\partial f(x,y)}{\partial xy} = 1 - y^{2}[/tex]
[tex]\frac{\partial f(x,y)}{\partial xy} = 2y[/tex]
.. correct? (I'm not too good on partial derivations :frown:)
So then:
[tex]2y = 2\left(-1 - \sqrt{2}\right) = -2 - 2\sqrt{2}[/tex]
.. which is positive.
[tex]2y = 2\left(-1 + \sqrt{2}\right) = -2 + 2\sqrt{2}[/tex]
.. which is negative.
Hopefully somewhat getting there! :smile:
hmm … this has become needlessly complicated.
It would have been easier at the beginning, instead of using the λ method (i know it has a name, but I've forgotten it :redface:), to simply use the directional derivative.
Since g(x,y) in this case is a straight line, in the direction (1,-1), all you needed to do was to find the directional derivative, ∇gf, in that direction, ie ∂f/dx - ∂f/∂y, which was y + y2 - x, and put that = 0 (subject to x + y = 1).
Substituting x = 1 - y gives ∇gf = 2y + y2 - 1 = 0 …
this is the same final equation as before, but without using λ ! :wink:
Now, to distinguish between maxima and minima, you need to know whether ∇gf is increasing or decreasing, so just consider d/dy (∇gf). :smile:
.. I was doing in the [itex]\lambda[/itex] way (um.. lagrange multiplier?!) as this is how I was taught a similar problem and hence should really use this way.
Looking back through my notes on this, once the values of x and y have been found (as they have been) then just put these into the original equation for f and then can deduce if the stationary point is a min or a max.
Basically, for the first point:
[tex]x = 2 + \sqrt{2}, y = -1 - \sqrt{2}[/tex]
.. input the values into:
and consider whether is positive or negative, and hence max or min point.
Then repeat for second point.
(oh yes, Lagrange multiplier! :rolleyes:)
But the problem with that method is that f(x,y) isn't necessarily positive at a maximum or negative at a minimum.
You can change it slightly, and say that if there are only two turning-points, at A and B, then either f(A) > f(B) or f(B) > f(A) …
in either case, the first one must be a maximum, and the second a minimum! :smile:
(of course, that doesn't rule out points of inflexion, so perhaps for completeness the values towards infinity in both directions should also be considered)
