Calculating term in Virial Expansion
  • Thread starter Thread starter MostlyHarmless
    Expansion Term
MostlyHarmless
...For each of the temperatures...compute the second term in the virial equation ##B(T)/(V/n)##, for nitrogen at atmospheric pressure.
##PV = nRT(1+\frac{B(T)}{V/n}+\frac{C(T)}{(V/n)^2}+...)##
I'm given a list of temperatures and values for B(T), for starters, Let T=100K giving B(T)= -160 (cm^3/mol).
I think I'm misunderstanding the question maybe. I'm confused on how I'm supposed to calculate the second term when I need the volume, but to find volume I need the second term. I'm also assuming I can just consider 1 mol of nitrogen.
You know P, R, T, and B(T), and you need to solve for V/n. Substitute y = V/n, and then solve for y. It will be a quadratic equation in y, and you will need to use the quadratic formula (or you can probably solve it iteratively by using successive substitutions).
Chet
Ok, that's what I tried doing. I did get an answer. It was close'ish to the answer I got when calculating V just from the ideal gas law, but off by a couple of factors of 10. I must have made some sort of conversion mistake.
Show us some of your work and maybe we can help.
chet
I'm going to try it a couple more times carefully before I subject my self to typing the quadratic formula with units and what not. :)
If you are using the quadratic formula, you may be encountering a roundoff problem. Is the 4ac term very small compared to the b2 term in the discriminant?
Chet
Ok, I found my problem. I left out T^2 when I substituted numbers into the variables on my white board. So I kept making the same mistake over and over.
Here's what I got, V=98.13cm^3 using the virial expansion and V=82.03cm^3 using the ideal gas law.
Does this seem like a reasonable difference at 100K?
Well, if B(T) is negative, wouldn't you expect V from the virial equation to be less than V from the ideal gas law? And, in addition, from the ideal gas law, I get 8203 cc/mole.
Chet
I wasn't converting one of the constants, so I'm in the right degree of 10 now.
It would make sense that V from the virial equation should be less than V from the ideal gas law. But now I've got 8358 cc/mole. Not really sure where I'm going wrong so quadratic formula madness is coming..
##P-Pressure=10.13 \frac{N}{cm^2}; R-constant= 8.31 \frac{J}{mol*K}=831\frac{N*cm}{mol*K}##
##PV^2 - nRTV - B(T)n^2RT = 0##
##V = \frac{-(-nRT) + \sqrt{(nRT)^2 - 4(P)(B(T)n^2RT)}}{2P}##
##V = \frac{(831*100) + \sqrt{(831*100)^2 - 4(10.13)(-160)(831*100)}}{2*10.13}##
##V = 8358 cm^3##
Just do it by successive substitutions. Start by substituting the result from the ideal gas law into the virial term, and then resolving for V/n again on the left side. Keep substituting the previous solution into the virial term and then resolving until the answer stops changing.
Chet
Ok, cool, now I've got V/n = 8147cc/mol. Which seems much more reasonable. Thank you!
On the other hand, though, why would the quadratic formula fail to give an accurate V?
There's a sign error in the 4ac term of your discriminant.
Chet
Where exactly? I've been working on it so long it's harder and harder to find my mistakes.
(-B)=+160
Ah ok, thank you. And just for completeness' sake, I found another error, I wasn't dividing by P and was misreading my calculator, my actual V/n was 8042 cc/mol.
So, how come it doesn't match the solution you got by successive substitutions? They should give the same answer.
Chet
No, that is the answer I get from successive substitution, the previous 8147 that I posted, was actually 8.147x10^4, and I still needed to divide by P to get my final answer.
So you get the same answer doing it both ways, right? (I too get 8042 using successive substitutions).
Chet
Yes, I get 8040 using the quadratic formula.
