Calculating the Dielectric Strength of multiple materials
The discussion revolves around calculating the dielectric strength of multiple materials placed between charged plates. Participants explore the relationship between dielectric strength and dielectric constant, as well as the implications of layering different dielectric materials in terms of capacitance and voltage distribution.
  • Some participants suggest that the total dielectric strength may not simply be an average of the dielectric constants, indicating a more complex relationship involving capacitance and voltage.
  • One participant proposes that each layer of dielectric acts as a capacitor in series, which requires calculating capacitance based on relative permittivity and thickness.
  • There is a distinction made between dielectric strength and dielectric constant, with some participants emphasizing that they represent different physical properties.
  • Concerns are raised about the original question's clarity, with suggestions that it conflates dielectric strength with dielectric constant.
  • Participants discuss the importance of imperfections in insulating materials, which can affect dielectric strength and lead to arcing under high electric fields.
  • Some mention the use of layers in high voltage insulation to mitigate the effects of pinholes and imperfections, enhancing overall dielectric strength.
  • There are references to the use of electrically floating layers of metal foil to manage voltage distribution across dielectric layers.
Participants express disagreement regarding the relationship between dielectric strength and dielectric constant, with no consensus on how to approach the calculation of total dielectric strength when multiple materials are involved. The discussion remains unresolved with multiple competing views presented.
Participants note that the dielectric strength is influenced by factors such as imperfections in the material and the configuration of layers, which complicates the calculations. The discussion also highlights the need for clarity in terminology when discussing dielectric properties.
SpiderPig
If I had two different materials between two oppositely charged plates, would the total dielectric strength just be an average of both dielectric constants with respect to each of their thicknesses? Or is it more complicated than that?
Material A is in full contact with one plate and material B is in full contact with the other plate.
It is more complicated.
Imagine the layers of dielectric are separated by equipotentials of foil.
Each layer of dielectric is then a single capacitor, one of several capacitors in series.
Work out the values of the capacitance for each layer, based on Er, area and d.
Each will have the same charge, so you can work out the voltage applied to each.
C = Q / V; V = Q / C.
Now you can work out which dielectric layer will limit the voltage of the series stack.
The question in the original post should be changed because a dielectric constant is not the same as dielectric strength.
The dielectric strength of an insulating material is its ability to act as an insulator.
The dielectric constant of an insulating material is its ability to store electrical energy.
When capacitors are connected in series, the relative voltage dropped by each capacitor, is inversely proportional to that capacitance.
The dielectric constant, Er, determines the capacitance, so it also determines the proportion of the voltage dropped by that layer of dielectric.
Here is some code for multiple layers of dielectric
Code:
' several layers of dielectric
Type layer
    d As Double     ' layer thickness in metre
    er As Double    ' relative permittivity
    vpm As Double   ' dielectric strength, V/m
    c As Double     ' capacitance of this layer
    vbd As Double   ' breakdown voltage of this layer
    qx As Double    ' maximium charge on layer
End Type
Dim As Integer i, n = 3    ' number of layers
Dim layer( 1 To n ) As layer
' initialise
Dim As Double area = 0.01   ' area of dielectric
' for each layer    d        er    vpm   c vbd qx
layer( 1 ) = Type( 0.001 ,    2,   5e6,  0, 0, 0 )
layer( 2 ) = Type( 0.0015,    5,   1e5,  0, 0, 0 )
layer( 3 ) = Type( 0.0001,   22,   5e5,  0, 0, 0 )
Const As Double Eo = 8.8541878128e-12   ' Farad / metre
Dim As Double elast = 0     ' elastance = 1 / capacitance
Dim As Double d_total = 0   ' total thickness
Dim As Double q_min = 1e30  ' minimum breakdown charge
' compute each layer, sum and select
For i = 1 To 3
    With layer( i )
        ' compute for this layer
        .c = Eo * .er * area / .d   ' capacitance
        .vbd = .d * .vpm            ' breakdown voltage
        .qx = .c * .vbd             ' limiting Q, from C = Q / V
        ' gather for later
        If Q_min > .qx Then Q_min = .qx ' find lowest charge limit
        elast += 1 / .c             ' sum the elastance
        d_total += .d               ' sum of thickness
    End With
Next i
' final combined
Dim As Double c_total = 1 / elast
Dim As Double v_total = 0
For i = 1 To n
    v_total += Q_min / layer( i ).c
Next i
Print " Series capacitance ="; c_total; " farad "
Print " Breakdown voltage  ="; v_total; " volts "
Print
Print " Average dielectric strength ="; v_total / d_total; " V/m"
Print " Average dielectric constant ="; d_total * c_total / ( Eo * area )
Print
## V = V_1 + V_2 = \frac{Q}{C_1} + \frac{Q}{C_2} ## (*)
(*) ## = Q\frac{d_1}{\varepsilon_{r1}\varepsilon_0A} + Q\frac{d_2}{\varepsilon_{r2}\varepsilon_0A} ##
Yeah, the OP question is confusing, since it mixes two different phenomena.
@SpiderPig -- Can you clarify whether you meant dielectric constant ##\epsilon## or dielectric breakdown strength? The latter phenomena is more complicated than the former. Thanks.
Yes it is confusing now that I'm reading it again! I'll edit it once I figure out where the edit button is...
I'd actually like to know both the dielectric strength & dielectric constant.
The "edit" button is at the bottom left of your posts, next to the "report" button.
I see it on post #8 of mine but it's not on post #1... I'll investigate, thanks.
Please don't edit old posts to try to fix things up -- it makes for a very confusing thread. Instead, just post any corrections in a new reply. Thanks.
An important subtlety with dielectric strength (the ability not to arc through at high electric field strengths across the insulator) is that there are typically pinholes and imperfections in the insulator that serve as starting points for the arc-throughs. That is why high voltage insulation is often done in layers, so that the pinholes and imperfections don't line up, which helps to raise the dielectric strength value of the overall double-insulation.
There is a timeout for most users to edit their posts. I think it's 24 hours, but I'm not sure. Again, it is best just to add a new reply with any corrections/updates. If you do edit a previous post to fix a mistake or something, please use strikethrough to show the wrong info and maybe bold to highlight the new info you've added. At least that way your change will be visible and obvious. Thanks.
That's a good point, I never thought about that.
That is why high voltage insulation is often done in layers, ...
Sometimes, electrically floating layers of metal foil or chrome, are used to define the equipotentials between the layers of insulation. That makes a stack of leaky capacitors, which is designed to share the total voltage, evenly across all layers. The equipotentials prevents failures by deep electrical treeing.
https://en.wikipedia.org/wiki/Electrical_treeing
With AC, the capacitance between the foil layers, equalises the voltage drop between equipotentials.
With DC, it is the controlled leakage between the layers, that forms a potential divider.
