Calculating the Displacement (Having Constant Acceleration)
The discussion focuses on the correct application of the displacement formula under constant acceleration. A key point is the importance of the order of operations, specifically that only time (t) is squared, not acceleration (a). Misunderstanding this can lead to incorrect units for displacement, as using (at)^2 instead of at^2 results in units of (m/s)^2. Participants emphasize the significance of proper formula setup and unit consistency in calculations. Overall, clarity on these fundamental concepts is essential for accurate displacement calculations.
epuen23
A pinewood derby car starts down a constant slope with a constant acceleration of 2.2 m/s2. What will be its displacement after 2.4 s?
d=vt+1/2at^2
Answer: 6.3 m
I'm just having trouble understanding 1) how to plug in the formulas correctly and 2) the correct manner of attacking this.
I feel like I'm missing something basic/simple. Any help is greatly appreciated! So far I've got:
D = (0) + .5(2.2m/s^2 x 2.4s)^2
Enrique
No, ##a## is not squared, just the time ##t##. ##at^2## means that ##a## is multiplied by ##t^2##.
This has to do with what is called "order of operations". Sometimes students are taught the mnemonic PEMDAS to memorize that order: Parentheses, Exponentiation, Multiplication/Division, Addition/Subtraction.
So without any parentheses you would do the exponentation ##t^2## first, before the multiplication by the other quantities.
In addition to #2, note that your units do not come out correctly if you do (at)^2 rather than at^2. Instead of meters, you would get (m/s)^2, which is not a good unit for a displacement.
Oh. My. Gosh! Thank you so much. I don't know how I missed that. Thank you!
Orodruin, thank you so much. I guess it was just a silly mistake I made and didn't catch it. Thank you!
