Calculating the electric field of a cylinder
The discussion focuses on calculating the electric field generated by a semi-infinite hollow cylinder with surface charge density sigma. It is established that the radial electric field components cancel out along the axis of the cylinder due to symmetry. The method to calculate the electric field involves using the superposition principle by treating the cylinder as an assembly of infinitely many rings of charge. The user seeks clarification on whether the electric field at the surface of the cylinder (x=0) is zero or not.
  • Understanding of electric fields and charge distributions
  • Familiarity with the concept of surface charge density
  • Knowledge of the superposition principle in electrostatics
  • Ability to calculate electric fields due to point charges and rings of charge
  • Study the derivation of the electric field due to a ring of charge
  • Research the application of the superposition principle in electrostatics
  • Explore the concept of electric fields in cylindrical coordinates
  • Learn about the implications of charge density on electric field calculations
Students and professionals in physics, particularly those studying electromagnetism, as well as educators looking to clarify concepts related to electric fields and charge distributions.
Bunnysaur
I'm trying to calculate the electric field due to a hollow cylinder. The cylinder is "semi infinite" with one end at x=0 and the other at - infinity, and radius R. I'm trying to calculate the field at a point x along the axis (not above the end of the cylinder). The cylinder has charge density sigma (the problem specifically states to use surface charge density instead of line charge).
Am I correct in assuming that the radial field cancels? I can't figure out how to set this problem up.
I'm also supposed to calculate the field at x=0, at the "surface" of cylinder. Is this point inside the cylinder with E =0, or no?
Any help would be much appreciated, thanks!
Well, first you are right that the radial force outward from the axis of the cylinder should cancel on the axis of the cylinder. One way to see this is through a basic "symmetry argument." Imagine there were a radial force away from one spot on the axis.
Now imagine we rotated the problem around the axis of the cylinder. The cylinder looks exactly the same, but the radial component is pointing in another direction! We have considered the same problem but gotten different answers about the radial component, so "by symmetry" it must cancel. Another way to see this is that any radial field from one part of the cylinder at a point on the axis would be canceled out by the the radial field from the opposing spot on the cylinder (i.e. the point that is directly across the axis).
Now: how to do this problem? Do you know how to calculate the electric field due to a ring of charge at a point sitting on the axis going perpendicularly through the center of the ring? Use the superposition principle to "build" the cylinder out of infinitely many rings.
So, I should calculate the field at point X due to a ring of charge with radius R, and then assume that I have infinitely many rings? Wouldn't that just lead to the field being infinite? I'm also under the impression that the closer the charge gets to the center of the ring (the second part of the problem) the larger the field gets, which would also lead to an infinite field.
I've been trying to finish this problem all day, and I'm not convinced that this is the proper way to do it...
  • · Replies 16 ·
