Calculating the Fringe Width without the value of its Wavelength
To calculate the fringe width without the wavelength, the relationship Y1/Y2 = D1/D2 can be utilized, where Y1 and Y2 are the fringe widths for two different distances from the slits. Given that the distance across 20 fringe spacings changes from 58mm to 74mm when the screen is moved 0.80m away, D2 can be expressed as D1 + 0.80m. By substituting the known values into the equation, D1 can be determined. Once D1 is found, the wavelength can be calculated using the fringe width equation. This approach allows for the calculation of fringe width without directly knowing the wavelength.
AJ786
Young's fringes, produced by monochromatic laser light passing through slits 0.60mm apart, are viewed on a screen. The distance accrose 20 fringe spacings on the screen is 58mm. When the screen is moved 0.80m away from the slits, the distance across 20 fringe spacings becomes 74mm.
Y = D(lamda) / d
Y = Fringe Width
D = Distance from slits to screen
d = spacing between slits
(lamda) = Wavelength
In the experiment wavelength and slit width is constant. There fore
Y1/Y2 = D1/D2.
Y1 and Y2 is given. D1 is not given. But D2 = D1 + 0.80 m.
Substitute these values in the above relation and find D1.
Then using the relevant equation, you can find the wavelength.
Are Y1 and Y2 0.60mm and 74mm as Y is what I need to calculate so surely this would not be given to me within the question ?
