Calculating the froce between two magnets
  • Thread starter Thread starter chui
    Magnets
The discussion centers on understanding the formula for calculating the magnetic force between two magnets, specifically the meaning of "mu," which represents the permeability of the medium, typically air. The permeability value for air is approximately 1.26 x 10^-4 Henry/meter. It is emphasized that magnetic monopoles have not been observed, and calculations should focus on magnetic dipoles instead, leading to a more complex formula that does not follow an inverse square relationship. Additionally, the magnetic force is not influenced by the mass of the magnets, as it is more closely related to charge and velocity, similar to electric forces. Overall, the Wikipedia formula provides a foundational understanding but does not fully account for real-life applications involving magnetic dipoles.
chui said:
I have a formula, taken from Wikipedia:
http://en.wikipedia.org/wiki/Magnet#Calculating_the_Magnetic_Force"
But I didnt get the meaning of "mu" in this formula..
can anyone explain?
\mu is the permeability of the medium between the magnets, in your case this is probably air, the value of \mu_{air} \approx \mu_0 = 1.26 x 10^{-4} \frac {Henry} {meter} [/tex].
Another thing that's worth pointing out is that magnetic poles (aka monopoles) have never been observed to exist, though theoretically they may have existed at very early times in the formation of the universe.
So if you want to calculate the force between a pair of real magnets like the kind you'll be likely to find on your refrigeratior, you'll need to work out the force between dipoles, not magnetic poles (aka monoples). This will lead to a much more complex formula, and a non-inverse square relationship for the force.
Modeling a magnetic dipole as a pair of magnetic poles some distance will be very useful in calculating the force between real magnets, but as far as real-life applicaitons go, the wikipedia formula has only done half the job.
no mass?
Well, Does this force not effected by the magnet Mass?! (unlike gravity etc.)
why is that?
The electric force between two charges depends on the charge, not the mass. The magnetic force is basically a relativistic correction to the electric force, so it depends on charge and velocity (i.e. current).
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
It may be shown from the equations of electromagnetism, by James Clerk Maxwell in the 1860’s, that the speed of light in the vacuum of free space is related to electric permittivity (ϵ) and magnetic permeability (μ) by the equation: c=1/√( μ ϵ ) . This value is a constant for the vacuum of free space and is independent of the motion of the observer. It was this fact, in part, that led Albert Einstein to Special Relativity.
