Calculating the Intersection of Two Cylinders at Right Angle
4 replies · 2K views · last reply
stunner5000pt
Consider two quarters of a cylinder of radius R. What is the volume of a the intersection of a two quarters of two cylinders if the quarters meet at a right angle? Two sides of the bounded region will be rectangular according to this arrangement. (see the diagram when it gets approved)
2. The attempt at a solution
I need to do this in Cartesian coordinates so here goes
let the Z axis be straight up, the X axis out of the page an the Y axis parallel to the page.
For the cylindrical part parallel to the X axis
[tex]V = \int_{0}^{r} dx \int_{0}^{r} \int_{0}^{\sqrt{r^2 - y^2}} dy dz[/tex]
For hte cylindrical parallel to the Y axis
[tex]V = \int_{0}^{r} dy \int_{0}^{r} \int_{0}^{\sqrt{r^2-x^2}} dx dz[/tex]
And the find the volume i need to subtract the above two??
  • Line drawing of an L-shaped solid made of two cylindrical quarter-sections joined at a right angle, with curved ends and straight edges.
I had simular problem once, but I was given that the volume of the whole region was eight times the part volume.
[tex]V = 8 \int_{0}^{r} {(r^2-z^2)}dz[/tex]
[tex]V = 8(r^2z-(z^3/3) |r[/tex]
[tex]V = (16*r^3)/3 units.[/tex]
Hope you figure this one out.
dont understand how you got your integrand to be r^2 -z^2?
Adn what do you mean by 8 times part volume?
If you "slice" horizontally at height z above the xy-plane then the slice has a side equal to
[tex]{\sqrt{(r^2-z^2)}}[/tex] and a area [tex]A(z) = r^2-z^2[/tex]
The slice is a rectangle with equal size on all sides. (what is it called in english?)
where [tex]a = {\sqrt{r^2-z^2}[/tex] is on side of that rectangle.
But you are wondering why ? I can't really explain it but when you have circular solids you use [tex]{\sqrt(r^2-z^2)}[/tex] where r = radius of the circle.
From the figure you posted these are two "1/4-th" circles
I'm sure someone can explain it better then me here.
