Calculating the Limit of Sequence $(y_n)$ with $(x_n)$ Limit = $\frac{\pi^2}{6}$
  • Context: MHB
  • Thread starter Thread starter Vali
    Limit Sequence
The limit of the sequence \(y_n = 1 + \frac{1}{3^2} + \ldots + \frac{1}{(2n-1)^2}\) is calculated to be \(\frac{\pi^2}{8}\). This is derived from the relationship between the series \(x_n = 1 + \frac{1}{2^2} + \ldots + \frac{1}{n^2}\), which converges to \(\frac{\pi^2}{6}\). By subtracting the sum of the even-indexed terms from the total series, the limit of the odd-indexed terms is determined, leading to the conclusion that \(\sum_{n=1}^\infty \frac{1}{(2n-1)^2} = \frac{\pi^2}{8}\).
  • Understanding of infinite series and convergence
  • Familiarity with the Basel problem and the value of \(\sum_{n=1}^\infty \frac{1}{n^2}\)
  • Knowledge of even and odd indexed series
  • Basic calculus concepts related to limits
  • Study the convergence of series and their limits in depth
  • Explore the properties of the Basel problem and its implications
  • Learn about the relationship between even and odd indexed series
  • Investigate advanced techniques in series manipulation and convergence tests
Mathematicians, students studying calculus or analysis, and anyone interested in series convergence and limit calculations.
Vali
I have the following sequence $(x_{n})$ , $x_{n}=1+\frac{1}{2^{2}}+...+\frac{1}{n^{2}}$ which has the limit $\frac{\pi ^{2}}{6}$.I need to calculate the limit of the sequence $(y_{n})$, $y_{n}=1+\frac{1}{3^{2}}+...+\frac{1}{(2n-1)^{2}}$
I don't know how to start.I think I need to solve the limit for all the sequence ( even n + odd n) then from the "big limit" I should subtract $\frac{\pi ^{2}}{6}$.How to start?
$x_n$ and $y_n$ are series ... sums of a sequence.$\left(1 + \dfrac{1}{2^2} + \dfrac{1}{3^2} + ... + \dfrac{1}{n^2} + ... \right)-\left(1 + \dfrac{1}{3^2} + \dfrac{1}{5^2} + ... + \dfrac{1}{(2n-1)^2} + ... \right) = \dfrac{1}{2^2} + \dfrac{1}{4^2} + \dfrac{1}{6^2} + ... + \dfrac{1}{(2n)^2} + \, ...$
$\displaystyle \sum_{n=1}^\infty \dfrac{1}{n^2} - \sum_{n=1}^\infty \dfrac{1}{(2n-1)^2} = \sum_{n=1}^\infty \dfrac{1}{(2n)^2} = \dfrac{1}{4} \sum_{n=1}^\infty \dfrac{1}{n^2} = \dfrac{1}{4} \cdot \dfrac{\pi^2}{6} = \dfrac{\pi^2}{24}$
$\displaystyle \text{note} \implies \sum_{n=1}^\infty \dfrac{1}{n^2} - \sum_{n=1}^\infty \dfrac{1}{(2n)^2} = \sum_{n=1}^\infty \dfrac{1}{(2n-1)^2}$
Hi!
Thank you for the response!I found a solution, I got $\frac{\pi ^2}{8}$
  • · Replies 18 ·
  • · Replies 16 ·
