Calculating the Rate of Water Height Increase in a Filling Swimming Pool
The problem involves calculating the rate of water height increase in a rectangular swimming pool being filled at a specified volume rate. The pool has varying depths, creating a sloped bottom, which adds complexity to the situation.
  • The original poster seeks guidance on how to set up the problem, indicating a desire to solve it independently. Participants suggest drawing a sketch to visualize the trapezoidal shape of the pool and to help understand the relationship between the water volume and height. There is discussion about identifying key quantities related to the problem.
Participants are actively engaging with the problem, with some offering suggestions for visual aids and others discussing the relationships between the quantities involved. There is no explicit consensus yet, but the conversation is moving towards clarifying the setup of the problem.
The original poster expresses difficulty in understanding the explanations provided, indicating a potential gap in foundational knowledge or visualization skills. The problem's constraints include the specific dimensions of the pool and the rate at which it is being filled.
notsosmartman
Ok, I've been trying to figure this problem out of an old textbook for a couple days but seem to get nowhere.
"A swimming pool with a rectangular surface 18 meters long and 12 meters wide is being filled at the rate of .80m^3/min. At one end it is 1.0 m deep and at another it is 2.5 m deep, with a constant slope between ends. How fast is the height of the water rising when the depth of water at the deep end is 1.0 m??"
Any suggestions on how to set the problem up? I would like to solve it myself, but would like a starting place!
Thanks, Caleb
Draw a sketch of a side view of the pool. From the side, the pool looks like a trapezoid, with vertical sides of 1 and 2.5 meters, and length 18 meters. If you put in coordinates for the two points at the end of the sloping bottom, you can find the equation of the line that forms the bottom edge of the pool. The volume of water in the pool between the times when the pool is empty and when there are 1.5 meters of water is the area of the triangle cross-section times the width of the pool.
Thanks Mark,
But I'm still having difficulty understudying your explanation. Maybe a sketch will help me understand?
Thanks, Caleb.
Yes, probably, but you should draw it. Just draw a sketch of the side view of the pool.
HAHA, i have made so many damn sketches on my dry erase board... but yeah i ican post any drawing on here because its a mac and its new to me...
Step 1, in any related rates problem, is to identify the two quantities that are to be related.
They pretty much tell us what one of those quantities is when they ask "how fast is the height of the water rising...?" And they strongly hint at what the other is when they say the pool is "being filled at the rate of .80m^3/min".
  • · Replies 16 ·
10K
