The discussion revolves around calculating the torque and power of a single piston engine. Participants explore methods for determining the forces acting on the piston and how to translate these into torque and power calculations. The conversation includes aspects of geometry, trigonometry, and numerical simulations related to engine design.
- Exploratory
- Technical explanation
- Mathematical reasoning
- Debate/contested
- One participant seeks guidance on calculating torque and power based on known forces on the piston and the leverage on the crank.
- Another participant suggests plotting gas pressure force and inertia force against crank angle to find the resultant force acting down the cylinder axis.
- There is a discussion about the accuracy of the numerical simulation and the choice of timestep for pressure calculations.
- A participant mentions the need to derive equations for piston acceleration and questions the necessity of knowing flywheel inertia.
- Concerns are raised about the correctness of derived equations, with one participant noting discrepancies in their constants compared to others.
- Participants discuss the relationship between ideal force from a PV diagram and actual force calculations, with one participant attempting to adjust their graph based on the intake and exhaust pressures.
Participants express various methods and approaches to the calculations, but there is no consensus on a single method or formula. Some participants agree on the general approach of plotting forces against crank angle, while others raise questions about specific calculations and assumptions.
Participants mention limitations in their references and knowledge, indicating that some discussions may be based on incomplete understanding or assumptions. There are also indications of varying levels of mathematical and physics background among participants.
This discussion may be useful for individuals interested in engine design, particularly those looking to understand the calculations involved in determining torque and power in single piston engines.
