Calculating Velocity of Object Dropped from 71.3m
  • Thread starter Thread starter Leoragon
    Velocity
The problem involves calculating the time it takes for an object to hit the ground when dropped from a height of 71.3 meters, as well as determining its velocity upon impact. The gravitational acceleration is given as 9.8 m/s².
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss various equations of motion, including the use of kinematic equations and energy considerations. There is an exploration of how to derive time from the equations provided, with some questioning the assumptions of initial velocity and position.
The discussion is ongoing, with participants offering different approaches to the problem. Some have attempted calculations and are seeking clarification on how to apply the equations when initial conditions differ from zero. There is no explicit consensus, but several productive lines of reasoning have been suggested.
Participants are navigating the implications of initial conditions (initial velocity and position) on the equations used. There is a focus on ensuring proper application of the quadratic formula in the context of the problem.
Leoragon
Object dropped from a tower at height of 71.3 metres
What is the time it takes to hit the ground? What is the velocity when it does?
gravitational acceleration = 9.8m/s2
V = ΔX/Δt
X = average velocity X time
I don't know a formula that would enable me to get the time.
Use the WELL-KNOWN equation i.e.
x = ut + [itex]\frac{1}{2}[/itex]at[itex]^{2}[/itex].
V = ΔX/Δt
Try to derive it from formula said by grzz.
u is initial velocity which is zero as they mentioned it that they dropped.
Or you can think it in terms of energy mgh=½mv^2 ...etc to solve for the final velocity. On the other hand vy=g*t so you get t.
I've tried solving for time and this was what I got:
X= Xo + Vot + 1/2at2
Vo = 0 (it's at rest)
Xo = 0 (also at rest)
a = 9.8m/s2
X = 71.3m
71.3 = 0 + 0 + (.5 X 9.8 X t2)
71.3 = .5 X 9.8 X t2
71.3 / .5 = 9.8 X t2
71.3 / .5 / 9.8 = t2
√(71.3 / .5 / 9.8) = t
t ≈ 3.81s
Does this mean that time equals: √X/.5/a ? If initial velocity and initial position equals 0?
If so, how do you calculate it if the initial velocity and position doesn't equal 0?
Same equation. Plug in the known initial position and velocity and solve the quadratic.
Not what I meant. I meant how to solve for "t"
Last time I checked, when you drop an object, the initial velocity is 0 and, if you wanted you could make your reference line the point at which you dropped the object and thus have the initial position be 0, but then you have to be careful with your signs.
Is any of this making sense?
That's what I thought you meant, and I thought I answered.
Xf= Xo + Vot + 1/2at2
If you know Xf, Xo, Vo and a, plug those in and solve the resulting quadratic to find t. Doesn't matter whether Xo and Vo are zero or nonzero, provided they're known.
But how can you get Xf if you don't have t? And in the quadratic, I'm not sure which ones would be a, b, or c. I'm thinking in the quadratic formula it's something like.
t = x
b = Vi
a = a
c = Xf
so it will then look like: at^2 + Vit - Xf = 0
I'm trying to figure this out.
t = x
b = Vi
a = a
c = Xf
Shouldn't the first term be ½at^2?
This whole discussion assumes you know everything in the equation except t.
In the OP, you had X0 = 0, V0 = 0, Xf = 71.3, a = g, and you solved it happily. To do that, you effectively rearranged the equation to be
(a/2)t2 + V0t + X0 - Xf = 0
Then you asked what if X0, V0 are nonzero, to which I answered, just plug those nonzero values into the same equation.
  • · Replies 16 ·
